LCD Refurbish All things related to LCD / Screen refurbish and repair |
06-17-2018, 08:42 | #1 (permalink) |
Junior Member Join Date: Nov 2003 Age: 53
Member: 45057 Status: Offline Thanks Meter: 3 | samsung lcd remove and reinstall without damage it i think must open thread for solution -opinion for samsung lcd remove and reinstall without damage it simple and cheap phone like j3-2017 j5-2017 need to put out lcd for make any serice inside that problem is old.....start from samsung s-5 and after now is very rarely so far I have not managed to have a good effect maybe because i dont use very hi temperature......I'm afraid I do not do damage i use hot plate 85c for 5 minute .....but lcd is not easily dismantled my next step is to buy baku bk-7321 on youtube are many solution but i think is fake your solution ??? |
The Following User Says Thank You to freecom For This Useful Post: |
06-19-2018, 05:54 | #5 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,033 | Do not spend [ a lot of ] money for useless things !!! Quote:
No one tell you that will be easy - if will - then all will change it at home. Keep patience and you will do the job. That's all. | |
The Following 2 Users Say Thank You to debeliamark For This Useful Post: |
06-19-2018, 08:17 | #6 (permalink) | |
Member: 45057 Status: Offline Thanks Meter: 3 | Quote:
90-95 c for how long time ? 5-6 minute ? or more ? with hot plate or dry hair ? | |
06-23-2018, 05:39 | #8 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,033 | Keep it until complete disassemby needed parts ... just to prevent Tº drop. In any case hot plate is better, due to deliver constant and predicted themperature during process, until hot air is just for small parts disassembly -> separate home buttons, flat cables, fingerprints ect .. |
The Following User Says Thank You to debeliamark For This Useful Post: |
03-03-2019, 05:01 | #10 (permalink) |
Junior Member Join Date: May 2004 Age: 48
Member: 65319 Status: Offline Thanks Meter: 5 | Alternative to alcohol for loca removal Is there an alternative to alcohol for loca glue removal? Is there any product where you could submerge the entire screen in it without damage or water damage spots? |
