09-16-2013, 16:40 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | VBAT LINE GROUNDED. set the voltage on 0.5 v first. then connect power supply and slowly increase the voltage until power supply auto off ( ex: if power supply off when 1.7v then set the voltage to 1.6) sure there is a capacitor or IC will get heat but take some times. if it is a capacitor just remove it . if it is a IC you need to check the schematics which function of that ic before before it . good luck |
The Following 2 Users Say Thank You to irfan_gsm For This Useful Post: |
05-04-2016, 17:20 | #6 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Italy, Sardinia Age: 32
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | But like galaxy s2, after removing this, the phone will not charge, im looking around to make a jumper otherwise i just replace the missing piece |
05-05-2016, 10:26 | #7 (permalink) |
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | If i try to replace the missing capacitor the phone full short again, so the problem isn't the capacitor at all but the ic charge, now phone charging alternativetly like plug n unplug the usb cable all the time, the battery will charge but the screen will stay perma on ... any suggestion ? what can i do ? |
