Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 06-30-2014, 11:01   #1 (permalink)
Bikash Shrestha's Avatar
Member: 589836
Sonork: 1637176:sbikash81
Thanks Meter: 48
samsung note 3 Charging paused. Battery temperature too high
samsung note 3 Charging paused. Battery temperature too high plz help
i changed charging connector flex changed software but no solve .i think its battery temperature sensor problem can any one solve it
Old 07-03-2014, 06:30   #2 (permalink)
Member: 589836
Thanks Meter: 48
Does anyone have solution about this
Old 07-03-2014, 06:38   #3 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
3 note what type ... missed because of its many types of this type of
Old 07-03-2014, 06:42   #4 (permalink)
Member: 589836
Thanks Meter: 48
it's note 3 n900 world wide model
Old 07-03-2014, 07:01   #5 (permalink)
GSMFEROZEPUR's Avatar
Member: 1900418
Sonork: Not Available Yet
Thanks Meter: 93
REhot charging ic,i think solve ur problem
Old 07-03-2014, 07:08   #6 (permalink)
Member: 1256984
Sonork: coosairam01
change chaging socket and fresh to set soual u r problem 100%
Old 07-03-2014, 07:14   #7 (permalink)
srt6's Avatar
Member: 826522
Thanks Meter: 33
?????????????????????????????????????????????????? ??????? simply try another battery
Old 07-03-2014, 07:15   #8 (permalink)
Member: 589836
Thanks Meter: 48
first read the post carefully before posting ok i had already changed it
Old 07-03-2014, 07:21   #9 (permalink)
Member: 589836
Thanks Meter: 48
i tried it but no success
Old 07-03-2014, 12:00   #10 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,629
samsung n900 sm-note 3 charging paused by temperature
first try to replace both its chargher heat controller
the second rehot ic U601 ..... see the image below:
don forget to press thank
The Following 2 Users Say Thank You to d-Artigo For This Useful Post:
Old 07-03-2014, 12:46   #11 (permalink)
Member: 905341
Thanks Meter: 998
chaing battery and charging ic
Old 07-07-2014, 07:00   #12 (permalink)
Member: 589836
Thanks Meter: 48
this jumper smokes the set did u even tried this solution
Old 07-08-2014, 03:05   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
first chk the continuty between jack pin to cap ,if link ok than no need to jump, secondly connect the wire from jack pin to +ve side of cap , i think u connect to -ve side of cap thats why jumper burnt ,
Old 11-01-2014, 01:19   #14 (permalink)
anw
anw's Avatar
Member: 1090041
Sonork: 100.1594914
Thanks Meter: 50
pls help me
my note-3 sm-n900
TH800/TH801 pin out or jumper
coz my board this 2 component printed damage
help me sir
ANW
Old 11-06-2014, 03:58   #15 (permalink)
Member: 2287656
my samsung galaxy note 3 does the exact same thing are there any solutions please guys i am not tech savy but if u break it down i can manage please guys any help would be great
The Following User Says Thank You to uneek05 For This Useful Post:
Page generated in 0.21931 seconds with 9 queries
