Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-26-2014, 00:43   #1 (permalink)
Member: 2077936
Thanks Meter: 21
Samsung Note 3 Sm-N900 Gyro/Acellerometer IC Replacement
Hi,
I have reflowed 2 Gyro/Acellerometer's successfully and replaced another one successfully.
The one I am having trouble had liquid damage and 4 of the pads we're damaged and lifted further upon removal. I have replaced a brand new IC but I need to know if there are any alternative points I can jumper to from the chip to complete the circuit.
The picture attached points towards the pads that are missing.
Any help would be greatly appreciated!
http://imgur.com/nu0l8i1
The Following User Says Thank You to loomingx For This Useful Post:
Old 11-27-2014, 00:09   #2 (permalink)
Member: 2237030
Thanks Meter: 9
You are lucky, that legs are NC (not connected)
The NC pads are come up easily...
The Following User Says Thank You to hhto For This Useful Post:
Old 11-27-2014, 17:58   #3 (permalink)
Member: 2077936
Thanks Meter: 21
any suggestions on why is it not working? I ordered two replacements IC's directly from Samsung (my shop does authorized warranty work) and I'm still getting nothing in the Sensor test screen.
Old 11-27-2014, 18:36   #4 (permalink)
Member: 2237030
Thanks Meter: 9
on saturdy i will work next time, than i can tell you more or take few pic of the schem
Old 11-27-2014, 18:42   #5 (permalink)
Member: 2077936
Thanks Meter: 21
Thank you very much! I was fairly sure that they were NC pads but I thought I'd double check with people that have more experience than myself.
Old 11-29-2014, 19:11   #6 (permalink)
Member: 2237030
Thanks Meter: 9
Old 11-30-2014, 19:25   #7 (permalink)
Member: 2077936
Thanks Meter: 21
From that schematic I can't see how the 4 pads that I lifted were all NC?
Old 11-30-2014, 23:48   #8 (permalink)
Member: 2237030
Thanks Meter: 9
The dot is at the first leg, so your missing pads are the 16, 17, and the 19, 21
Old 11-30-2014, 23:58   #9 (permalink)
Member: 2077936
Thanks Meter: 21
oh ok to RESV and AUX_DA are still technically NC's. I'll hopefully take a look at the board sometime tomorrow. Thanks again!
Old 12-02-2014, 20:04   #10 (permalink)
Member: 2077936
Thanks Meter: 21
I have a SM-N900W8 Note 3. I tried locating the capacitors from the schematic you provided off of the SM-N900 service manual but the layout is different and doesn't allow me to locate them.
Any suggestions?
Old 12-04-2014, 01:45   #11 (permalink)
Member: 2237030
Thanks Meter: 9
SM-N9005
More few things, which are can help you to find the fault easier.
-All sensors use this voltage: VREG_LVS1_1P8 and data lines (SENSOR_I2C_SCL, ..._SDL) so if all other sensors (light, baro, proxy) are works fine than the U201 and the U606 probably working properly.
In this case remain two things: soldering defect or component fault
I hope I could help
The Following 2 Users Say Thank You to hhto For This Useful Post:
Old 12-04-2014, 19:05   #12 (permalink)
Member: 2077936
Thanks Meter: 21
Thanks you for all your support! Nothing on the *#0*# Sensor test works but the replacement IC was purchased directly from Samsung so I am almost certain that it is not the fault. Does this mean it's more likely the u201 or u606?
I also replaced the 8RHD component with a non pentaband Note 3 model with a different label. Could this have any affect on the Gyro/Acellerometer not working?
Old 12-06-2015, 17:01   #13 (permalink)
Member: 869889
Thanks Meter: 107
hello
all gsm friend pleases need help ,Samsung N900 display light problem ,fast time only Samsung logo than light off .after time coll incoming & outgoing ok but no display light .next time original display Chang for not solve .
Page generated in 0.20628 seconds with 8 queries
