11-26-2014, 00:43 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2077936 Status: Offline Thanks Meter: 21 | Samsung Note 3 Sm-N900 Gyro/Acellerometer IC Replacement I have reflowed 2 Gyro/Acellerometer's successfully and replaced another one successfully. The one I am having trouble had liquid damage and 4 of the pads we're damaged and lifted further upon removal. I have replaced a brand new IC but I need to know if there are any alternative points I can jumper to from the chip to complete the circuit. The picture attached points towards the pads that are missing. Any help would be greatly appreciated! http://imgur.com/nu0l8i1 |
The Following User Says Thank You to loomingx For This Useful Post: |
11-27-2014, 17:58 | #3 (permalink) |
Member: 2077936 Status: Offline Thanks Meter: 21 | any suggestions on why is it not working? I ordered two replacements IC's directly from Samsung (my shop does authorized warranty work) and I'm still getting nothing in the Sensor test screen. |
11-27-2014, 18:36 | #4 (permalink) |
Junior Member Join Date: Aug 2014 Location: United Kingdom
Member: 2237030 Status: Offline Thanks Meter: 9 | on saturdy i will work next time, than i can tell you more or take few pic of the schem |
The Following User Says Thank You to hhto For This Useful Post: |
12-02-2014, 20:04 | #10 (permalink) |
Member: 2077936 Status: Offline Thanks Meter: 21 | I have a SM-N900W8 Note 3. I tried locating the capacitors from the schematic you provided off of the SM-N900 service manual but the layout is different and doesn't allow me to locate them. Any suggestions? |
12-04-2014, 01:45 | #11 (permalink) |
Member: 2237030 Status: Offline Thanks Meter: 9 | SM-N9005 More few things, which are can help you to find the fault easier. -All sensors use this voltage: VREG_LVS1_1P8 and data lines (SENSOR_I2C_SCL, ..._SDL) so if all other sensors (light, baro, proxy) are works fine than the U201 and the U606 probably working properly. In this case remain two things: soldering defect or component fault I hope I could help |
12-04-2014, 19:05 | #12 (permalink) |
Member: 2077936 Status: Offline Thanks Meter: 21 | Thanks you for all your support! Nothing on the *#0*# Sensor test works but the replacement IC was purchased directly from Samsung so I am almost certain that it is not the fault. Does this mean it's more likely the u201 or u606? I also replaced the 8RHD component with a non pentaband Note 3 model with a different label. Could this have any affect on the Gyro/Acellerometer not working? |
12-06-2015, 17:01 | #13 (permalink) |
Freak Poster Join Date: Sep 2008 Location: bangladesh
Member: 869889 Status: Offline Thanks Meter: 107 | hello all gsm friend pleases need help ,Samsung N900 display light problem ,fast time only Samsung logo than light off .after time coll incoming & outgoing ok but no display light .next time original display Chang for not solve . |
