03-26-2015, 10:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Ireland
Member: 397374 Status: Offline Thanks Meter: 26 | Samsung Note 8 touch problem I've changed digitizer in Samsung Note 8 and works very strange. Once I am using pen provided everything is fine, if I use finger touch is responding randomly. I've checked 2 digitizers, also I've put foam between screen and glass so they don't touch each other. I didn't use LOCA. Do you have any ideas? Thanks in advance |
03-26-2015, 13:33 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
first check C1027 = 6.6 V (C its value in 2200 nF, 10%, 16V) and track data / clock touchscreen R6061-R6062 his (its R-value of 2.2 K ohms. 1%, 1 / 20W, TP, 0603) rehot second regulator ic touch her see the image below: only press thank | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
