02-15-2015, 11:35 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 945648 Status: Offline Thanks Meter: 0 | Samsung S3 common problems I have here two Samsung S3, each with a very common problem upon Google search, but I haven't found a solution for any. Maybe you can help.. 1st I have a i9300 with the very common problem of people not listening well during calls. Already replaced mic without success. Works fine with viber, etc, also, if during call I press a bit harder at bottom of the battery people listen better. 2nd I have a i9305 with a dead lcd. No falls, no cracks, nothing, just went dead! Tried the i9300 lcd and works fine. Already cleaned contacts, lcd pcb and still persists. I want to try a light reflow on the lcd pcb chips but I'm afraid to melt the plastic.. Can anyone help me with either or both these issues? Thanks in advance. |
02-16-2015, 16:03 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,619 | Quote:
1. samsung gt-i9300 ways mic solution rehot ic audio ... see picture below : 2. try to replace lcd her .... from your description above his troubled lcd | |
The Following 2 Users Say Thank You to d-Artigo For This Useful Post: |
02-16-2015, 16:25 | #4 (permalink) |
Member: 945648 Status: Offline Thanks Meter: 0 | Thanks d-artigo, Will try to re-heat mic ICs when I get home. Regarding lcd, could it be a bad chip instead of whole lcd module? Can I apply voltage somwhere in lcd module to see if it works? Thanks. |
