07-28-2016, 16:05 | #1 (permalink) |
Junior Member Join Date: Jul 2016 Location: e.b magalona neg. occ
Member: 2601288 Status: Offline Thanks Meter: 2 | samsung s4 i9505 dead but detected on pc(HELP) |
The Following User Says Thank You to maxalvarado For This Useful Post: |
07-28-2016, 17:46 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 176003 Status: Offline Sonork: bb pin 27883543 Thanks Meter: 74 | Can you view the folders on the phone via pc?if so then replace the lcd Sent from my GT-I9505 using Tapatalk |
The Following User Says Thank You to clebo For This Useful Post: |
07-29-2016, 16:03 | #3 (permalink) |
Member: 2601288 Status: Offline Thanks Meter: 2 | no sir. but when i plug it to my pc it detect. and when i open odin it detect. com6 i try my lcd to another s4 its work perfectly |
07-29-2016, 16:28 | #5 (permalink) |
Member: 2601288 Status: Offline Thanks Meter: 2 | sir can you help me how to make a TFlash card. i tried to flash in odin but it says setup connection. i already try to a power supply but still it says setup connection i also tried to use another battery but still the same. no luck |
07-30-2016, 13:24 | #7 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Check with tester continuity esd filters upper fpc lcd connector, replace or jumper. for description they are 6 black small quadrangular components with 6 pin. |
