07-14-2016, 09:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | Samsung s4 on and off after 2 seconds Even on download mode or recovery power on and off very quick. any help... |
07-14-2016, 21:31 | #4 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Nigeria,Delta
Member: 786852 Status: Offline Thanks Meter: 31 | Its not power botton problem. Its boot problem. Find in the ATF Forum for Samsung I9505 SDC file for boot repair and format a good memory card probably 2gb mmc(not the HC type memory card), copy the. SDC file corresponding to your phone make and latest version. Place the memory card in the phone memory card slot and boot to download mode, you will notice it will not switch off again den flash with latest four files rom with PIT file your phone will work 100% Last edited by mbond; 07-14-2016 at 21:36. Reason: Typographical Errors |
07-15-2016, 00:22 | #5 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | How do i know what is the version of my i9505 if the phone wont boot. I download sdc for 4.4.2, now i put the file in memory card, and turn on in download mode. Correct? |
The Following User Says Thank You to XPTO2511 For This Useful Post: |
07-15-2016, 01:22 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | boot your phone in download mode if phone stays in download mode then its related to software if phone restart in download mode also then its 100% power button, just change it! Regards .::M Irfan::. |
07-16-2016, 01:14 | #7 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | i phone enter download mode and goes off imediatly. if is power button problem when i put the phone to charge the phone should display the baterry... and this is not the case... i'm correct or worng? |
07-16-2016, 07:05 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | follow wat members told u first replace power button and post result |
The Following User Says Thank You to HUM For This Useful Post: |
