05-16-2015, 10:28 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Samsung S5 G900F block the touch screen when i put the charger phone is new not used when the phone is in charging process touch screen blocked does not work i flash the phone but the same situation i think is hardware problem any help |
05-16-2015, 12:42 | #3 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | yes offcourse becouse phone is new and in the Box of new phone is original charger also i check the phone with another chargers sam situation |
05-16-2015, 15:39 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-g900f touch problem clean its B to B connector rehot try his touch controller ic or replace with a new one see picture below | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
05-17-2015, 04:23 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | try with other chargers, solved same problem in other brand phone ....when set is on charging touch stops working so i change charger and problem solved |
The Following User Says Thank You to HUM For This Useful Post: |
