Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 12-12-2016, 09:57   #1 (permalink)
Member: 2621291
Thanks Meter: 124
Samsung S5 G900F microphone repair solution - mic filter IC U805 replacement
I would like to share with you my lastest repair. I was able to fix microphone issue by replacing mic filter IC U805. You will find the whole operation recorded on the tape below this post.
Link to the video - mic filter replacement
The Following User Says Thank You to eselekt For This Useful Post:
Old 03-01-2017, 07:56   #2 (permalink)
Member: 2634426
Thanks Meter: 15
Hi, lately I accidentaly damage some connectors on the motherboard. I need to make a jumper, have you got a scheme for this phone, please?
Old 08-23-2017, 08:51   #3 (permalink)
Member: 2621291
Thanks Meter: 124
To find the right scheme visit our facebook group USEFUL VIDEOS ABOUT ELECTRONIC REPAIR you will find there your solution.
Old 08-23-2017, 11:45   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
samsung S5 sm-G900F microphone ways
remove U805 microphone regulator and jumper
File Type: jpg samsung s5 sm-G900F microphone ways.jpg (272.0 KB, 208 views)
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 09-08-2017, 18:43   #5 (permalink)
Member: 2630469
Thanks Meter: 8
Good job Artigo, do I have to remove U805, wont that destroy the motherboard?
Old 09-20-2017, 06:53   #6 (permalink)
Member: 2724771
Thanks Meter: 12
You will not destroy the mainboard, you should be careful not to damaged chip, because if you do, the phone will not boot properly.
Old 09-28-2017, 06:46   #7 (permalink)
Member: 2621291
Thanks Meter: 124
Remember to use CAPTION TAPE, this is a key to a safe soldering which allow you to protect the other components.
Old 10-02-2017, 21:51   #8 (permalink)
Member: 2634426
Thanks Meter: 15
Should I use caption tape while replacing micro usb / charging port in my Xperia Z3 Compact.
Old 10-11-2017, 07:29   #9 (permalink)
Member: 2764058
I am a new one here, what the caption tape is? When should I use it?
Old 10-17-2017, 17:19   #10 (permalink)
Member: 2630469
Thanks Meter: 8
Caption tape protect components before high heat it prevent damage.
Old 10-23-2017, 13:11   #11 (permalink)
Member: 2621291
Thanks Meter: 124
Refreshed link to the tutorial:
http://www.youtube.com/watch?v=MiXqGUdxMms
Old 11-28-2017, 11:59   #12 (permalink)
Member: 2634426
Thanks Meter: 15
How is this chip called?
Old 12-11-2017, 07:37   #13 (permalink)
Member: 2621291
Thanks Meter: 124
It's microphone chip U805
Old 12-14-2017, 14:35   #14 (permalink)
Member: 2748073
Thanks Meter: 8
What temperature should I apply to this replacement?
Old 12-15-2017, 09:54   #15 (permalink)
Member: 2621291
Thanks Meter: 124
The temperature of soldering iron should be around 300 celius degree.
Page generated in 0.27377 seconds with 9 queries
