06-03-2014, 14:30 | #6 (permalink) |
Junior Member Join Date: May 2014 Location: Ghana
Member: 2196025 Status: Offline Sonork: [email protected] Thanks Meter: 0 | auto power for samsumg firstly clean the board only with a smooth brush to clear dirt and other substances and then replace charging port/ unit and check 10000000000000000000 solution |
06-01-2015, 18:12 | #7 (permalink) |
Junior Member Join Date: Feb 2013 Location: west bengal kolkata
Member: 1883469 Status: Offline Thanks Meter: 2 | samsung 5222r auto power on when insert battery.. i change on/off switch charging socket..and also remove resistor from charging track but till same problem any soluation ..plz help me. |
06-24-2015, 09:03 | #8 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Kolkata, India Age: 53
Member: 1164699 Status: Offline Thanks Meter: 62 | Don't replace cc or switch first. chek continuity of both point of pwr switch. one gnd and one vpwr. If those are shot then dismount the switch. now connect the battery. Is your set auto powering without switch? then replace the cc. If not then pwr on your set without switch (by a tweezer touch), mostly set will be powered on. Now wash your old switch and resolder pcb switch point, chek the old switches if it is shot, and fit on pcb. Don't use iron, use hot air gun. I solved a problem today sam 5222R without changing any cc or switch. |
