07-04-2013, 15:44 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | samsung GT-S5360 Y display light first rehot ic light U502 if it still work as before check the voltage U502 at C512 check its light path in R514-L601 and C617-U612 check lcd light enable it in R515 if the light is still good supporting components ... replace light ic U502 see the picture below (where the position of the component) only thank button |
The Following 2 Users Say Thank You to d-Artigo For This Useful Post: |
08-08-2013, 10:01 | #4 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1960068 Status: Offline Thanks Meter: 1 | How to check the volt on component & on which side how many volt should i check? I don't have light ic of s5360 .... So also show me how to put jumper |
The Following User Says Thank You to tanveerlandge For This Useful Post: |
