06-04-2016, 11:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | Samsung S6 - works only on charger The device - G920F was water damaged, powers on and works only while charging, if I unplug the usb cable the phone just dies straight away. Power button works, battery connector seems fine. I had same problem before and didn't manage to fix it Any idea what the problem could be? Thanks Kim |
06-05-2016, 09:16 | #3 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Quote:
2-change power botton 3-resolder ucp3002 and check 4_resolder ucp5000 and check 5-replace ucp3002 and check 6-replace ucp5000 and check | |
10-14-2016, 07:22 | #4 (permalink) |
No Life Poster Join Date: Aug 2002 Location: BULGARIA Age: 53
Member: 14868 Status: Offline Thanks Meter: 44 | did you manage to fix it? have the same unit for repair, but not water damaged. SUB board - ok, on C8070 and C8051 - 9V while charging. Service manual says change U7015. |
10-14-2016, 10:41 | #5 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 225506 Status: Offline Thanks Meter: 31 | change battery or charge battery with external power charger i resolt this problem with charge battery with external chager few minit after phone charge normal problerm is tempurature battery |
