07-12-2019, 14:15 | #1 (permalink) |
Major Poster Join Date: Dec 2010 Location: Dhaka
Member: 1478712 Status: Offline Thanks Meter: 13 | Samsung Galaxy A10 A105F Charging Paused Solution so you Need to remove the thermistor and replace from the other board. Just Follow the Picture Shown Below In order to overcome the water damage problem, all you have to do is to: Clean charging dock strip and check. If the problem persists or if the pins are damaged then you need to replace the entire charging dock strip. Now check the voltage of 1st pin (from right) of charging connector with the help of a Multi-Meter, if there is a problem then re-solder charging pin. Now check voltage at the capacitor, if it is zero then check whether it is short or not if it then changes the capacitor. If not then: Check the connection between the charging pin and Capacitor, if the connection is broken re-solder it or place a jumper. The charge is provided to the Samsung Galaxy A10 A105F board via Capacitor. Last edited by Monsur017251964; 07-12-2019 at 14:21. |
