06-05-2006, 12:20 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 53
Member: 91905 Status: Offline Thanks Meter: 3 | Samsung Secret Codes SAMSUNG: *#06# -> Displays imei *2767*5282# -> Java Reset and (Deletes all Java Midlets) *2767*63342# -> Reset Media (Deletes All Sounds and Pics) *2767*927# -> Wap Reset *#9998*4357# -> Help Menu *#9998*5282# -> Java menu (GRPS/CSD settings for JAVA server) *#9999#0# -> Monitor Mode *#9999# or *#9998*9999# -> Software Version *#8888# or *#9998*8888# -> Hardware Version *#9998*746# or *#9998*0746# or *#0746# -> Sim Infos *#9998*523# or *#9998*0523# or *#0523# -> Display Contrast *#9998*842# or *#9998*0842# or *#0842# -> Vibration On (until you push OK) *#9998*289# or *#9998*0289# or *#0289# -> Buzzer On (until you push OK) *#9998*288# or *#9998*0288# or *#0288# -> Battery & Field Infos *#9998*377# or *#9998*0377# Error log *#9998*778# or *#9998*0778# or *#0778# -> Sim Service table *#9998*782# -> show date and alarm clock *#8999*638# -> show network information *#9998*5646# -> change operator logo at startup *#9998*76# -> production number *#9998*968# -> view melody for alarm *#9998*585# -> Non-Volatile Memory (NVM) *#3243948# -> Digital Audio Interference Off *#32436837# -> Digital Audio Interference *#9999# -> Show Software Version *#0837# -> Show Software Version (instructions) *#0001# -> Show Serial Parameters *#9125# -> Activates the smiley when charging. *#9998*228# -> Battery status (capacity, voltage, temperature) *#9998*246# -> Program status *#9998*324# -> Debug screens *#9998*364# -> Watchdog *#9998*427# -> Trace Watchdog *#9998*544# -> Jig detect *#9998*636# -> Memory status *#9998*785# -> RTK (Run Time Kernel) errors *#9998*786# -> Run, Last UP, Last DOWN *#9998*837# -> Software Version *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*872# -> Diag *#9998*947# -> Reset On Fatal Error *#9998*999# -> Last/Chk *#9998*9266# -> Yann debug screen (=Debug Screens?) *#9998*9999# -> Software version *2767*2878# -> Custom EEEPROM Reset *2767*3855# -> Full EEPROM Reset This code will remove sp lock in some models But also changes IMEI to 447967-89-400044-0, ____________________________________________ Samsung s300 unlock code enter these 5 codes without sim card in phone! your phone should then be unlocked 1. *2767*63342# 2. *2767*3855# 3. *2767*2878# 4. *2767*927# 5. *2767*7822573738 ____________________________________________ Samsung v200 unlock codes Enter these codes into phone without sim in phone This will not work on some new versions 1. *2767*63342# then press green button 2. *2767*3855# then press green button 3. *2767*2878# then press green button 4. *2767*927# then press green button 5. *2767*7822573738# then press green button |
All SamSung Secret Code!!! | jupiter888 | Samsung Flashers, Software, Firmware. | 17 | 07-01-2009 17:59 |
samsung secret codes | manndi | Java, iOS, Android, Symbian development | 0 | 07-19-2008 19:20 |
samsung secret code | gabar1985 | Cruiser Suite | 4 | 05-06-2008 09:17 |
samsung secret code | gabar1985 | Cruiser Suite | 1 | 04-10-2008 11:33 |
Samsung Secret Codes (s0ftbank) | ulymar | QUALCOMM Models (3G) | 3 | 09-21-2007 10:55 |
