Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-26-2016, 03:57   #1 (permalink)
Member: 844312
Sonork: 100.1640471
Thanks Meter: 257
Arrow Samsung SM-J700F (J7) Fake Charging Solution [Available]
Samsung J7 hardware solution fake charging done 100% working
Samsung SM-J700F
The Following 6 Users Say Thank You to sohidul For This Useful Post:
Old 11-29-2016, 14:18   #2 (permalink)
Member: 2629656
sir
my problem samsung grand prime sm-g530h headphone solution need
The Following User Says Thank You to jalal865687 For This Useful Post:
Old 01-15-2017, 14:07   #3 (permalink)
Member: 2226403
Thanks Meter: 32
how the problem solved by removing power ic
Old 03-31-2017, 18:43   #4 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
It's a very lazy and simple direct charging solution for any android devices. I am not commanded this solution but you my try it.
Old 03-31-2017, 20:22   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
@gsm-raj ,
by removing or bypass ic , mobile not work for everything . you need to replace it with new or working one for perfect work .
and that's not a power ic . that's a usb charge pump up (charging ic) ic .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 04-07-2017, 19:07   #6 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
Originally Posted by .:SARCAR:. View Post
@gsm-raj ,
i agree with u man........
The Following User Says Thank You to ekel For This Useful Post:
Old 04-07-2017, 19:14   #7 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 96
IC name is SM-5703a .. wich have charging ,,
he alrady mention the ic position ,
an other use full thing wich i can shere with friends , that some time we got J700h short like wich is taking 13 14 pulsss on power supply , that problem i solved many times in this ic SM-5703a .
Old 10-21-2017, 08:56   #8 (permalink)
Member: 2038521
Thanks Meter: 3
Samsung j700f fake charging done by using diot ... i also do not recommend for this direct volt passing solution .
but i just show you when you can not fix and think ic changing too much risky for you so you can try this method ..
The Following User Says Thank You to Shopneelakas For This Useful Post:
Page generated in 0.17718 seconds with 8 queries
