01-30-2018, 23:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: new zealand
Member: 1624770 Status: Offline Sonork: 1640429 Thanks Meter: 98 | samsung sm-t355 back light issue i have problem here this Samsung sm-t355 back light not working please can anyone help me to solve my problem thanks |
01-31-2018, 02:39 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-T355 display light first check the D6000 and L6001 if either ..rehot or replace ic light U6004 | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
01-31-2018, 04:25 | #4 (permalink) | |
for jumper I have not done it ... more clearly see the light ic data SKY82896 below | |
01-31-2018, 08:31 | #5 (permalink) | |
Member: 1624770 Status: Offline Sonork: 1640429 Thanks Meter: 98 | Quote:
To be honest with you I can’t figure this out Reading voltage and you explain in more in photo and mark with point This will be a great help Thanks Sent from my iPhone using Tapatalk | |
06-20-2019, 14:09 | #7 (permalink) |
Junior Member Join Date: Jun 2019 Location: California
Member: 2914524 Status: Offline Thanks Meter: 1 | Hello dear friends! I also have same tablet T355 with same trouble (no image, no power up, heating up below led driver cover. As I check: burn out inductor L6001 and diode D6000 - looks like similar. But I can't find any information about diode and inductor model&size anywhere!!! In SKY82896 datasheet (IC driver for led backlight) I found a reference schematic for typical application, and again - no info about used parts I even found a service manual (I can provide it if needed) with full schematic of tablet, but again (bad luck!) no parts. Please help me! |
06-20-2019, 14:55 | #8 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: Spain
Member: 1826697 Status: Offline Thanks Meter: 76 | Quote:
* 2703-003897 L6001 INDUCTOR-SMD check this page for same parts in other phones/tablets Samsung Spare Parts | Mobile Phone | Feature Phone | GT-B3800FKTXSA | Version 0004 | SAMSUNG INDUCTOR-SMD * 0404-001669 D6000 DIODE-SCHOTTKY check this page for same parts in other phones/tablets Samsung Spare Parts | Camera | NX Camera | EV-NX3000BOHAU | Version 0000 | SAMSUNG DIODE-SCHOTTKY * 1203-008519 U6004 IC-BACKLIGHT DRIVER check this page for same parts in other phones/tablets It seems that there are some more models that have this IC but it's not clear. Samsung Spare Parts | Mobile Phone | Tablet | SM-P350NZAAXSA | Version 0001 | SAMSUNG IC-BACKLIGHT DRIVER Hope it helps a little | |
The Following User Says Thank You to jm_rg94 For This Useful Post: |
06-22-2019, 21:19 | #10 (permalink) |
Member: 2914524 Status: Offline Thanks Meter: 1 | Hello dear friends! Many thanks again to jm_rg94, information that he provide to me was very useful Knowing L6001 INDUCTOR-SMD real value, I made a temporary checking (using bigger parts soldering with wires) of display light: inductor was burn out (clearly seen by eyes!), diode was good (my mistake). And after inductor temporary replace (4.7 µH needed) I found a bad capacitor C6031 (inside a metal shield). For test I replace this capacitor with external 2200nf 50V capacitor - display light going up, and a tablet was return to life and begin to charge! Can you provide me a part number of C6031 capacitor? May be a good idea to find real size and value of this part. |
06-22-2019, 21:32 | #11 (permalink) | |
check this page for same parts in other phones/tablets Samsung Spare Parts | Mobile Phone | Mobile Accessory | GT-B9150ZKAXSA | Version 0004 | SAMSUNG CERAMIC CAPACITOR SMD | |
07-22-2019, 12:26 | #13 (permalink) |
Member: 2914524 Status: Offline Thanks Meter: 1 | Hello guys! Many thanks to efrcom for non-original part numbers - they much cheaper and more available in stores. As a result of the repair - broken parts was changed in this way. smd-inductor L6001 (p/n samsung 2703-003897) was changed to Murata p/n 1239AS-H-4R7M=P2 (4.7 µH, 30%, size 1008 [metric size 2520!], 1MHz) smd-capacitor C6031 (p/n samsung 2203-007790) was changed to Murata p/n GRM31CR71H475KA12L (4700NF,10%,50V,X5R,TP,size 3216 [metric size 1206!] Please note - Murata parts are a little higher than original parts (0.5mm). But they can short to a metal shielding cap then closing it - put a thin strip of Scotch clear tape (packing tape) to inside of cap. Tablet will light up and working good! |
The Following User Says Thank You to sergsol For This Useful Post: |
