11-09-2018, 13:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Samsung T335 tab 4 8.0 strange problem. Tanks Pandemonio100 |
11-12-2018, 16:16 | #3 (permalink) |
Member: 3381 Status: Offline Thanks Meter: 1,171 | The problem is not sure is pmic because power on normally and drain battery only when tab is On. Also others caps around the tabs go in shorcut not all. BUt servicd manual exist for this tab? |
11-12-2018, 17:24 | #4 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | and why could not it be the pmic? check if there is something similar to a battery ic in the vicinity of the connector, normally on samsung it could be 6/9 pins. the Schematic for this model is not found unless some virtuoso here in the forum has it. Read the abbreviation above the ic and do an online search. |
