Samsung Tab A T580 charge port Hello, I've a problem with charging port for Samsung Tab A T580. Third pad is loose on the motherboard. I need to find where I could apply a jumper, wire to which capacitor in order to get this third pad working and charge port to work. Has anybody been through and get me the charge port solution for this model, Please. |
I found sth but this solution is for t560 and my model is t580, slightly different with the way capacitors are on the motherboard http://www.u2ugsm.com/blog/wp-conten...umper-Ways.jpg I still need to know where to solder the jumper from the charging port pad. |
Take a picture of the board from 2 sides in good quality as in the photo from T560 |
Please see pictures. http://i64.tinypic.com/126fwgz.jpg http://i68.tinypic.com/2a5j70m.jpg http://i63.tinypic.com/2nluxvo.jpg |
... or you can scratch that circle pad that goes on board another layer, and measure directly .... just my 5 cents ... did it in the past ... Of course, service manual is a g0d :) b.r. Alex |
I sorted out this tablet by applying the jumper but not to this fuse, soldered to the fuse beside the one you marked on the picture, first one on the left. Tablet is finally charging. Many Thanks for your effort and support. |
http://i68.tinypic.com/9aabh1.png |
Sorry for hijacking this thread but i have lifted three pads on the same tablet T580 The pads ive lifted are the one in the picture above and the two directly to the right. does anyone know of alternative solder points please? |
link is not working Quote:
hello i have changed a new charging port without success. do you have the charging ways picture please ? |
Hi Bro, Please can you send me jumper pic you did i faced the same problem in T585 and this link is removed https://drive.google.com/file/d/1XdF...GCqGh6DMg/view Thanks |
