Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-07-2018, 20:31   #1 (permalink)
Member: 1514899
Thanks Meter: 49
Samsung Tab A T580 charge port
Hello,
I've a problem with charging port for Samsung Tab A T580.
Third pad is loose on the motherboard.
I need to find where I could apply a jumper, wire to which capacitor in order to get this third pad working and charge port to work.
Has anybody been through and get me the charge port solution for this model, Please.
Old 11-08-2018, 01:06   #2 (permalink)
Member: 1514899
Thanks Meter: 49
I found sth but this solution is for t560 and my model is t580, slightly different with the way capacitors are on the motherboard
I still need to know where to solder the jumper from the charging port pad.
Old 11-08-2018, 18:32   #3 (permalink)
Member: 305873
Thanks Meter: 14
Take a picture of the board from 2 sides in good quality as in the photo from T560
The Following User Says Thank You to waliko2003 For This Useful Post:
Old 11-09-2018, 00:37   #4 (permalink)
Member: 1514899
Thanks Meter: 49
Thank You for response.
Please see pictures.
Old 11-09-2018, 21:34   #5 (permalink)
Member: 305873
Thanks Meter: 14
here try.
https://drive.google.com/open?id=1Xd...FVsTdGCqGh6DMg
Old 11-09-2018, 23:08   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,609
... or you can scratch that circle pad that goes on board another layer,
and measure directly ....
just my 5 cents ... did it in the past ...
Of course, service manual is a g0d
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 11-10-2018, 10:40   #7 (permalink)
Member: 1514899
Thanks Meter: 49
Thank You for your help.
I sorted out this tablet by applying the jumper but not to this fuse, soldered to the fuse beside the one you marked on the picture, first one on the left.
Tablet is finally charging.
Many Thanks for your effort and support.
Old 11-10-2018, 10:52   #8 (permalink)
Member: 1514899
Thanks Meter: 49
Forgot to share the final solution,see image:
Old 12-17-2018, 19:48   #9 (permalink)
Member: 6999
Thanks Meter: 6
Sorry for hijacking this thread but i have lifted three pads on the same tablet T580 The pads ive lifted are the one in the picture above and the two directly to the right. does anyone know of alternative solder points please?
Page generated in 0.27907 seconds with 7 queries
