07-06-2017, 06:17 | #1 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2290247 Status: Offline Thanks Meter: 0 | Samsung Tab2 P5100 hot problem i have a Samsung Galaxy Tab 2 10.1 P5100 won't turn on when i put the charger o the battery the place showing in the pic become very very very hot i can't touch it until i take off the battery links to image : https // ibb dot co/jjpB2v plz delete the space betwwen letters any idea please thanks |
07-13-2017, 02:32 | #5 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | samsung gt-P5100 battery connector ways try with a new battery ... is it still hot check positive and negative battery connectors how big its shorting value analysis : check its battery connector path one by one both replace U717 and TA700 |
The Following User Says Thank You to d-Artigo For This Useful Post: |
07-14-2017, 02:43 | #7 (permalink) | |
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
of the image you are bringing up. Its heat is around the display area does this phone fall or hit the water ..? 1. check the working voltage of the lamp in the lcd connector in C814 and C828 and measure back with avometer = shorting missing not 2. if still shorting pull C804 ... if still shorting .. replace Inductor SMD L801 (marked: 6R8) | |
