Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-03-2006, 10:08   #1 (permalink)
crossings's Avatar
Member: 9897
Samsung V200 problem -when try to use CAMERA -''DECONNECT DATA CABLE OR IRDA''
Samsung V200 problem -when try to use CAMERA -''DECONNECT DATA CABLE OR IRDA'' error. I clean it conector same problem ,flashed ,reset MMI no results
Old 02-03-2006, 15:17   #2 (permalink)
byteforce's Avatar
Member: 21296
Sonork: 100.1575170
It is a well-known problem, and there is a solution for it. Download the repair flash from unlockeasy and flash that firmware to phone and then you will have a working V200 again.
Old 02-03-2006, 15:43   #3 (permalink)
falak's Avatar
Member: 74749
thisa is charging jack problm put any samsung cable and then start camera it ll work.if yes then check out charging jack its short.
thankx
falak
bb5 king software geting close when try to use .:M@ster:. BB5KING 1 11-21-2008 13:05
U600 when want to use camera it says:please wait beneto Samsung Hardware Repair Area 1 03-06-2008 17:42
6233 restert when try to opeen camera Softway Nokia Hardware & Hardware-Repair Area 4 01-29-2008 05:12
6230i when tryin to use camera "Memory Full pls delete memory" whereas it empty insid ReyTech Griffin 6 06-17-2006 17:16
problem when try to flash Nokia 3310 Ciux MT-BOX 8 02-21-2006 17:01
Page generated in 0.25326 seconds with 11 queries
