06-03-2006, 13:11 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 43
Member: 156269 Status: Offline Thanks Meter: 3 | Samsung X100 Hang and Restart plz help 1) my Samsung X100 Mobile when i charging mobile then after 20 min charging show full charging my mobile. 2) When i charging mobile same time hang. 3) when i make call my mobile auto restart same time. plz help me thanks |
The Following User Says Thank You to gsm_mobile_zone For This Useful Post: |
06-05-2006, 09:48 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In Heavan
Member: 229987 Status: Offline Sonork: 100.1602834 Thanks Meter: 193 | Change Batery and try............................................... .. |
The Following User Says Thank You to lahoot For This Useful Post: |
06-05-2006, 12:42 | #4 (permalink) | |
No Life Poster Join Date: Sep 2005
Member: 183043 Status: Offline Thanks Meter: 68 | Quote:
i have exactly the same problem.but if i try to connect phone to ns dongle or twister the software boxes cannot detect phone.i changed the charging block, and still no difference.the phone went dead and didn't want to power on at all, and after about 4 hours i tried again and it switched on....so i reckon it is the flash ic. | |
The Following User Says Thank You to W4r10rD For This Useful Post: |
06-07-2006, 10:38 | #6 (permalink) |
Registered User Join Date: Oct 2004 Age: 43
Member: 86890 Status: Offline Thanks Meter: 9 | its hardware problem, soak the panel in a mixture of thinner and spirit then heat the power ic strongly. Tested and works perfectly |
The Following User Says Thank You to elkirf For This Useful Post: |
06-09-2006, 15:27 | #8 (permalink) |
Member: 156269 Status: Offline Thanks Meter: 3 | thanks all my X100 good work no hang and no restart just i change my mobile battery my mobile 100% work good thanks all |
06-10-2006, 18:32 | #9 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 288244 Status: Offline Thanks Meter: 7 | HI I solved that problem too many time Firstly Clean PCB and Give Small hot 5 and air 3 100% solved your problem good LUCKKKKKK |
The Following 2 Users Say Thank You to ansari_nazeel For This Useful Post: |
samsung c200 hang and restart | HUM | Samsung Hardware Repair | 1 | 11-12-2009 08:11 |
x100 hang and restart | travolta | Samsung Hardware Repair | 18 | 03-04-2009 05:30 |
x100 hang and restart | sayedhas | UST Pro II | 5 | 01-18-2009 11:03 |
Samsung D900 Hang and Restart please help... | ASHRIFF | UST Pro II | 0 | 10-30-2008 14:50 |
samsung c200 hang and restarts | HUM | Samsung Hardware Repair | 2 | 10-16-2005 20:15 |
