03-28-2011, 12:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 340774 Status: Offline Thanks Meter: 164 | sasmsung galaxy i9000 charging prob plz give soloution with pic or with schmentic dont post fake soloutions |
01-15-2012, 16:35 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | Here's some hints on how to fix the Samsung I9000 Galaxy S Not Charging Problem: 1. Ensure that the battery charger you are using is properly working or try to use another one. 2. Visually check the USB pin connector for possible damaged. Clean it if oxidized, re-solder, or replace it if necessary. You can read the VBUS charge voltage at the pin #1 if the USB connector is okay. 3. Check or read the VBUS Charge IN voltage this is the output from the VBUS charger control IC. 4. Re-heat, rework the VBUS IC if the 5V is missing. Replace if necessary. 5. The power management IC will be the next option to re-work at if the procedures above doesn't solved the problem. |
01-15-2012, 16:41 | #5 (permalink) |
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | Samsung Galaxy S I9000 Not Charging Problem Solution The picture below shows some components of the Samsung I9000 Galaxy S, it points a test spots where to start a check up or troubleshooting procedures. It also show us which and what components needs to check first. |
04-12-2012, 12:17 | #7 (permalink) | |
Major Poster Join Date: Sep 2004 Location: yap
Member: 82476 Status: Offline Thanks Meter: 4 | Quote:
12-13-2013, 12:12 | #11 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2083882 Status: Offline Thanks Meter: 0 | Hi all, I'm going to repair my I9000 usb connection but I would like to know before if I could try to power on the main board without battery, screen, etc. to test if 5v is ok on pin 1 of the USB connector. Will I damage the main board if powered without the other component ? thanks a lot. |
12-14-2013, 16:28 | #12 (permalink) |
Member: 2083882 Status: Offline Thanks Meter: 0 | Hi, I did the procedure described in I9000 service manual p.36. using the mainboard only. IFC300 (usb connector) pin #1 is 5V : OK U503 DCIN (on C502 capacitor) is 4V instead of 5V ... is it ok ? Could it be U301 beeing dammaged ? Thanks a lot for your feedback... Regards, |
12-14-2013, 17:05 | #13 (permalink) |
Member: 2083882 Status: Offline Thanks Meter: 0 | by the way, here is a description of why I am trying to repair my I9000. When phone is off and I connect it to USB charger, there is an empty battery symbol and that's all. there is no battery filling animation on the screen as it should be. |
12-15-2013, 17:07 | #15 (permalink) |
Member: 2083882 Status: Offline Thanks Meter: 0 | hi, thanks for your answer. battery should be ok because I tested with another one. current battery is 3.9V and is ok to boot the phone. battery connector is ok, tested with ohmmeter. when powerwing only the mainboard with usb 5V, I measure around 3V on battery connector beetween middle pin and (left or right pin). there is 0v beetween left and right pin. Do you have information concerning battery connector pin ? What about 4V instead of 5V on output from VBUS charger control IC (VBUS Charge IN voltage) ? thanks for your help |
Phone Not Charging | tiggerwilk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 10-21-2012 16:23 |
Charging. | PhoeniX | Nokia Hardware & Hardware Repair | 7 | 07-06-2004 08:35 |
51xx charging problem | kage | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 03-06-2002 00:42 |
how to charge your battery? | g2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 09-26-2000 14:32 |
7110 contrast setting prob... | RiddleR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-04-2000 02:53 |
