07-24-2014, 04:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Australia
Member: 1817312 Status: Offline Thanks Meter: 13 | Seeking bypass solution for i9100T with broken RF switch Seems the client tried plugging in an external antenna in to the Galaxy S2 / i9100T and subsequently the internal antenna now is disabled. Reception is good with a 90mm length of wire plugged in to the RF socket, but that obviously isn't a solution. Is there a bypass / link I can solder on to get around this broken RF socket? |
07-24-2014, 04:46 | #2 (permalink) |
Member: 1817312 Status: Offline Thanks Meter: 13 | Based on this datasheet, if I can actually remove the device I should be able to simply short the two internal pads.... getting it off thus far however has been less than successful, even with preheating, hotair and low-temp-solder. http://www.farnell.com/datasheets/58824.pdf |
07-24-2014, 05:19 | #3 (permalink) |
Member: 1817312 Status: Offline Thanks Meter: 13 | All fixed. Had to push the hot air to 360'C, which is more than I usually deal with. Single 0R 0603 SMD resistor used to bridge the two inner pads left after removing the antenna test socket |
