Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-18-2014, 12:53   #1 (permalink)
Member: 31028
Thanks Meter: 56
separate lcd from frame
i can easily separate glass from lcd, but not lcd from frame because of the lcd back adhesive, anyone tried a method that's efficient, adhesive dissolver etc?
regards
Old 09-19-2014, 18:36   #2 (permalink)
Member: 2140872
Thanks Meter: 5
The technique I use is to separate the sides of the glass from the frame, while leaving the tools to pry on the side, I dip the frame+lcd assembly in isopropyl alchool 99% 2 min. It will loosen the glue under lcd. Use heat + dipping in IPA to work all around the frame and it should separate from the frame.
Make sure you remove microphone, speaker, cameras etc.. from frame before dipping in IPA
The Following 2 Users Say Thank You to EC911 For This Useful Post:
Old 09-19-2014, 18:43   #3 (permalink)
Member: 2250967
I use the same method as EC911 minus the heat.
Old 09-19-2014, 18:46   #4 (permalink)
Member: 2140872
Thanks Meter: 5
This technique also works on S4, Note3..
Old 10-27-2014, 01:43   #5 (permalink)
Member: 279803
Can any 1 tell me what is the best degrees to separate Iphone4 ,5 and 5s Lcd's ?
Page generated in 0.14783 seconds with 8 queries
