Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 08-23-2005, 19:15   #1 (permalink)
Member: 3508
Question SGH-D500 - keys 2,5,8,0,6 don't work!!
Hi!
Does anyone know what can be the problem!?
Keys 2,5,8,0 and 6 don't work, all other keys work perfectly! Sometimes they work perfectly and then again don't work...it drives me crazy!!
Phone wasn't water damaged but I cleaned PCB, removed C766-775 which are linked to the kepay, removed microphone, and again the same!!
Can flat cable be the problem!? Or any other idea!?
Old 08-23-2005, 19:20   #2 (permalink)
07heaven's Avatar
Member: 57937
Its usually the flat cable, but from my experience its been the upper slide keys that don't work, when the flat cable is at fault
but I guess while doing you other repairs you have disconnected it and reconnected it, if it is the flat cable, usually disconnecting and reconnecting sorts the problem out
Old 08-23-2005, 19:21   #3 (permalink)
07heaven's Avatar
Member: 57937
Have you peeled back the white membrane and cleaned the contacts underneath the keypad?
Old 08-23-2005, 20:05   #4 (permalink)
Member: 3508
Yes I cleaned and the PCB and membranes, and upper keys work perfect but I don't know if bad flat cable can make problem with lower side of the phone!!
Maybe will try to power on the phone without keyboard and membranes and try keys with screwdriver to see what will hapend!
Old 08-23-2005, 20:32   #5 (permalink)
CPUKILLER's Avatar
Member: 76257
check for corrosion on lower end of flex cable(the side towards main pcb)
Old 08-23-2005, 20:43   #6 (permalink)
Member: 71751
check the board for current reading on each of those keys it could be due to current failing to reach those keys,then ofcourse you'll have to trace the resistors necessary for that.
Old 08-24-2005, 09:12   #7 (permalink)
Member: 78934
i am sorry i can not help you
Old 08-31-2005, 06:08   #8 (permalink)
Member: 3508
I find out what is problem, flat is OK, I tried this with open phone when I harder press the lower PCB keys work, when I release it a little bit they stop working!! So somewere is some line broken, or solder is broken!!
Is there any IC for keyboard or it goes directly to CPU!?!?
Old 09-01-2005, 17:16   #9 (permalink)
adomshima's Avatar
Member: 78679
Try re-soldering the cpu, i have try it on samsung A 200.
Old 09-02-2005, 03:43   #10 (permalink)
Member: 3508
Yes I know that it will solve the problem, but CPU is glued!!!
Old 09-02-2005, 13:24   #11 (permalink)
Member: 23157
You must to mesure with your instrument.
Keypad is broken because CPU is confused with the strange information,he think that is more keypad is pushed on.
Old 09-02-2005, 16:07   #12 (permalink)
Member: 3508
You didn't read all my posts!! Phone is open, without membranes and make contact with screwdriver, and when I press harder PCB keys work, if I realese it a little bit they stop working!!
Old 09-02-2005, 17:28   #13 (permalink)
themobileking's Avatar
Member: 5072
By the info that you have given it seems that you have 1-2 tracks broken. Probably because the phone fell down or something like that .Please check all the main keypad tracks ....that should solve the problem.
Rgds
Old 09-04-2005, 00:02   #14 (permalink)
Member: 33320
I have same problem like you, but you must to mesure with your instrument to fix this stupid problem.
B.R.
Dusko
Old 09-05-2005, 12:52   #15 (permalink)
Member: 164613
Change The Flex Cable!!!!!
3200 keys 2,5,8,0 line not working ?? infogsm Nokia Hardware & Hardware-Repair Area 2 11-21-2006 19:32
Nokia 6101 - Keys 2,5,8,0 doesn't work - Help! Thams Nokia Hardware & Hardware-Repair Area 2 02-26-2006 06:45
7250 key 2,5,8,0 not working-help shachash Nokia Digital Core Technology 4 ( DCT-4 ) 6 01-06-2005 07:12
6150 keys 2,5,8,0 don't work... trafix Nokia Hardware & Hardware-Repair Area 4 08-29-2004 13:53
Page generated in 0.35096 seconds with 11 queries
