07-05-2008, 11:49 | #5 (permalink) |
Freak Poster Join Date: Jun 2003 Location: LZ - Bulgaria
Member: 30940 Status: Offline Thanks Meter: 13 | The same here, i measure resistance about 200 ohm of PIN 9 of charger conector to ground - it is JACK IN pinout for indetification of the handsfree. On the handsfree speakers and mic work OK. Remooved F500 and internal speaker work now. If you dont want to loose HF and COM port fuctionality - change F500. |
The Following User Says Thank You to symbiah For This Useful Post: |
07-05-2008, 17:51 | #7 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | its' not hw problem it's software phone is E250d unlocked as E250 so he will have this problem for that microbox use for E250 E250v E250d read cod not direct unlock cause eeprom will bee damaged |
07-11-2008, 16:40 | #8 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | sh it i have same problem i got e250D unlocked via simcard trick with reset code. then my customer wants to remove orange icons by flashing e250D with flash from e250 after that phone couldn't make calls and also there was a problem with recognizing of memory card. i flash that e250d with flash E250D_XDGI1 so now phone is working fine exept that speaker don;t work that speaker working fine if i choose LOUD speaker mode so it;s not hardware problem. i hear i should write eeprom. i don;t have HWK. how to fix It? |
12-10-2011, 22:40 | #9 (permalink) | |
Freak Poster Join Date: Sep 2009
Member: 1121593 Status: Offline Sonork: 100.1604641 Thanks Meter: 9 | E250 Working Solution 100% tested!! Quote:
Hello Sir, this is the 100% working solution. I have a green board E250 Samsung phone. I flashed with E250 flash file, after that, no network, no sound. I flashed with everything, all flash files in the world (JOKE) and all eeproms..nothing worked, until i read your solution. Problem is if you flash with files of E250D BUT as E250, you WON'T get any good results. Solution would be flash E250D files as E250D. 1-flash good eeprom E250D 2-repair imei since it will be 000000000000. 3-flash normal files. 4- At Last type *2767*3855# to reset the phone. 5-WORKING PHONE AS RESULT. Thanks. BR | |
c6000 speaker ways loudspeaker working but ear speaker not work | shani72 | Chinese Models & Cloned Phones | 3 | 06-19-2011 06:54 |
1200 speaker and way ok but speaker not working why ?????????????????????????? | tiju kkm | Nokia Hardware & Hardware Repair | 11 | 04-07-2010 01:19 |
E65_1 speaker not working help me speaker is ok | shani72 | Nokia Hardware & Hardware Repair | 3 | 11-14-2009 08:58 |
e250 speaker not working | vikas chadha | NSPRO | 11 | 08-24-2009 03:30 |
2310 speaker not working but loud speaker working? | albert139 | Nokia Hardware & Hardware Repair | 5 | 05-25-2009 21:19 |
