07-29-2017, 14:36 | #1 (permalink) |
Junior Member Join Date: Mar 2002 Location: Warrington UK
Member: 9911 Status: Offline Thanks Meter: 6 | Sm-j510fn no display phone came in with water damage , theres no display , i cant find the right schematic to order the 3 small chips that have a DX marked on them phone is now recogonised by pc but MTP DRIVER fails to install probrably due to usb setting not set to file transfer does anyone have circuit description or part numbers for the very small ics thanks |
07-30-2017, 03:42 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-J510FN display first try replacing the lcd with the new one both check its lcd working voltage at C6039 = 3.0V and at C6038 = 1.8V replace the damaged and if both its either check or replace diode U5006 LDO 3.0V (AP7340D-30FS4-7-71 DIODES) with part number: 1203-008326 and U6004 LDO 1.8V (AP7340D-18FS4-7, DFN10) with part number : 1203-008250 which you are three sets under the U5006 two under it with one part number and currently the replacement of the other has not been updated yet | |
The Following 2 Users Say Thank You to d-Artigo For This Useful Post: |
08-08-2018, 13:29 | #3 (permalink) |
Junior Member Join Date: Jul 2012 Location: Russia
Member: 1786147 Status: Offline Thanks Meter: 0 | Same problem here. C6039 - 3.0V ok C6038 - 1.8V ok Changed DCDC but still no display. Tried to change LCD but no results... Is there any normal schematic for this phone. I found one SM but there is nothing about LCD part( |
