06-01-2018, 19:16 | #5 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2653719 Status: Offline Thanks Meter: 0 | My sm-j530f has been damaged by water, i could switch it on only only once touching the motherboard while connecting the usb cable to the transformer and i tested the phone and backed up some data too... Instead if i only leave the usb plugged in it buzzes,you can see the first screen and then it shutdown repeating the cycle. Now trying again multiple times i can only reach the bootloader which is interesting too. What are those pins visible on the motherboard? Can i backup some data easily even from the bootloader? What is ADB enable file? I suspect the only damaged thing is the circuit to switch the phone on, so i'd like to know more about the components i see on the motherboard. |
07-09-2018, 14:45 | #7 (permalink) |
Member: 2653719 Status: Offline Thanks Meter: 0 | klcheng, do you know where's the S2MU005X03 on the j530 board? What's under the 110#1 and 111#1 metal cap? i hope not to damage anything near these caps while trying to remove them thery're both a little bit burned in my opinion. |
07-09-2018, 18:19 | #8 (permalink) |
Member: 2653719 Status: Offline Thanks Meter: 0 | i don't know how to modify my last post... i found my power ic under the metal cap 110#1 it was quite difficult to unsolder it with my hot air gun..i also ended up scratching a little bit the corner of the tfa9890c and twisting a little bit my motherboard since i used two clamps to hold the board... hope my audio will be ok guys what do you think. Now i need to arrange a little bit those balls...i ended up having half of those spheres on my broken ic and the other half on the pcb |
08-19-2018, 05:53 | #10 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | Quote:
samsung J5 SM-J530F display no picture first check the LCD working voltage at C7061 and C7062 second rehot emi lcd filter ny at F7010-F7011-F7012-F7013 and F7014 if damaged it can be in a jumper third rehot ic backlight driver U7007 | |
08-23-2018, 20:01 | #11 (permalink) | |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | Quote:
can you tell me if can i check those voltages in the display connector. thanks | |
08-24-2018, 16:10 | #12 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi i have checked first the C7061 voltage and i haven't any voltage there. i have not checked the 1.8v in C7062 because i have 1.8v in lcd connector. the emi filters are good because they have continuity and i have between 0.2 and 0.5 volts in the filters and lcd connector. i haven't schematics, then i can't know where comes the 3v (C7061) from. any help? thanks |
07-05-2019, 11:17 | #13 (permalink) |
Freak Poster Join Date: Jan 2009 Location: SRB
Member: 941075 Status: Offline Thanks Meter: 51 | here is schematics https://gofile.io/?c=PBecRb |
The Following 4 Users Say Thank You to coyote_kv For This Useful Post: |
