11-06-2016, 11:43 | #1 (permalink) |
Junior Member Join Date: Jul 2012 Location: Uzbekistan Age: 36
Member: 1779553 Status: Offline Sonork: 10075 Thanks Meter: 1 | SM-N920C Please help me dm-verity verification failed |
11-13-2016, 11:16 | #2 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2643333 Status: Offline Thanks Meter: 1 | hello friend as start i apologize for my bad english i have encountered this problem before on my G935FD , and it's really big **** . - first , you can't flash or make any repair process because of frp block protection . - second , your DM problem make your device unbootable so you stuck in recovery mode with some redlines about dm fail . after 10 days working on it , guess what ? i finally solve the problem and i'll help you right now so here's this simple and spectacular solution : 1 - flash your device with official firmware . 2 - after flashing you have to connect your device into download mode again and give it FRP/EE Reset with any supported dongles . for me i've used BST " this is the most important step " . 3 - while flashing FRP File you'll see " custom binary blocked by frp " don't worry it's ok . 4 - restart your device into recovery mode . 5 - use volume keys and select " reboot to bootloader " 6 - congratulations now your device booted up again . 7 - after booting up your device will ask you about owner gmail accout as usually , just write it or bypass it via accepted ways . 8 - after finish your installation go to settinges . enable developer options , disable OEM Unlock . 9 - now you able to flash any custom recovery , just flash TWRP and root your device . " this is important to fixing DM files in your device " after root , the problem solved and your DM have been fixed |
The Following User Says Thank You to algoorithm For This Useful Post: |
