Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-09-2006, 20:09   #1 (permalink)
silveraxe's Avatar
Member: 166746
Soldiering LCD's onto flexis / flats. best way / tips please??? -urgent-
HI.
I am having some trouble removing lcd's that are soldeired from the pcb or placing new ones onto pcb which need soldiering,
for eg.: The E700, i want to remove the big n small lcd from damaged flex/flat cable and place it onto new flex cable,
What is the best way to remove / replace the lcd to and from new old cable.
Another eg. I want to change C100 samsung LCD, i tried with air gun and with sodlier iron, sometimes its messing up. please advice soem tips ;>
Old 01-15-2006, 17:49   #2 (permalink)
bentys2000's Avatar
Member: 28334
good thread i think !!! i'll appreciate an help too !!! pictures and video ...
best regards
Old 01-15-2006, 18:03   #3 (permalink)
verse1965's Avatar
Member: 56365
Yes would be appreciated also. It took me two tries to replace R225 lcd to pcb board. Not fun, and luckily it was cheap lcd not expensive new model.
I had taped it in place then solder one line on each end to keep it straight. Looks easy but is not because lcd connector is very sensitive.
Regards, JOHNNY.
Old 01-30-2006, 06:20   #4 (permalink)
Member: 183723
u can use hot air with decent heat and low air to take out LCDs.
move it slightly from beginning of flat to the middle ,when u see it is the time try to take it out carefully from the outer side and and continue using hotair slowly to the end.
Old 02-14-2006, 14:19   #5 (permalink)
zahid_mobile's Avatar
Member: 203615
some time working well and some time not working anyone give the vido of this that how to remove the lcd with pcb
thanks in the advance
zahid
Old 03-04-2006, 07:35   #6 (permalink)
silveraxe's Avatar
Member: 166746
I managed to remove E700 lcd from flexi cable
and put it onto new cable the large lcd works 100%
but the small lcd i fitted 3 new ones, it jsut wont display even with magnet in place... any ideas???
2310 charging ways please urgent meeru Nokia Hardware & Hardware-Repair Area 5 04-14-2009 10:10
SonyEricsson K510i ON/OFF Ways Picture........Very urgent please repmob Sony Ericsson Hardware Repair Area 0 01-14-2009 15:06
G1500 power switch ways & led ways needed............plz....urgent smgujar LG 0 08-21-2007 15:24
Best way to install Fighter onto XP Mastah-GSi Cruiser Suite 11 03-13-2005 18:31
Best way to unlock my T18, please HELP!!! Husocan Old Ericsson Phones & Sony Phones 5 09-25-2000 01:20
Page generated in 0.26493 seconds with 11 queries
