05-11-2006, 09:21 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 271900 Status: Offline Thanks Meter: 0 | T809/D820 Serial Flash Cable Shematic |
05-14-2006, 13:45 | #3 (permalink) |
Member: 271900 Status: Offline Thanks Meter: 0 | OK, didn't get any response so I figured it out myself. This one is tested and working great. Please disregard the last schematic. I just flashed my T809 to a D820 using this circuit. I used One NAND Downloader v18 Lite. Make sure the battery is fully charged because this takes a long time to flash. Turn the phone off. Plug everything in. Launch One NAND Downloader. Select the firmware files (cla and tfs). Select the com port your cable is plugged into. Set the speed to 115200. Check the "Don't Auto NAND Format" box as well as the "BIN + TFS" box. Press the start button. Now push the power button on the phone (don't hold it down). The app should find the phone. Next press the download button. Wait till it finishes downloading both files (takes like 40 min). Unplug the phone. Pull the battery and reinstall it. Power up the phone. Should be flashed to the D820 if all went well. Also you will need to setup T-Zones as well as MMS if you want to use them. Here are the settings... T-Mobile , T-Zones Proxy Settings 1) Go to your browser settings on the main menu 2) Select "Settings" 3) Adjust the settings of one of the given preset programs to the following: Profile name: T-Zones (that's mine, you can name yours whatever) Home URL: http://wap.myvoicestream.com Bearer: GPRS only Proxy: Enable then select the GPRS settings tab IP address: 216.155.165.50 Port: 8080 APN: wap.voicestream.com Login/Password: LEAVE BLANK MMS Settings 1) Go to your messages setting on the main menu 2) Select "Multimedia Messages" 3) Select "Settings" 4) Select "MMS profiles" 5) Select "Profile Settings" 6) Select one of the preset settings and adjust to the following: Profile name: MMS (again you can choose your own) Server URL: http://216.155.174.84/servlets/mms Proxy: Enable Version: 1.2 (295 kb) --then select the GPRS settings tab IP address: 216.155.165.50 Port: 8080 APN: wap.voicestream.com Login/Password: LEAVE BLANK |
Need T809/D820 UFSx-N-Box Flash Cable Shematic | dtd1215 | Samsung Hardware Repair | 0 | 07-01-2006 11:39 |
T809/D820 Serial Flash Cable Shematic | DaOne | SWIFT Platform | 0 | 05-11-2006 09:44 |
samsung e710-e700 data/flash cable shematics needed. | PaRoZ | Samsung Hardware Repair | 2 | 07-22-2005 15:31 |
9210 flash cable shematic for griffin | mobidoc | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-11-2003 22:48 |
Flash Cable Shematic? | feverdj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-28-2002 23:09 |
