04-16-2008, 20:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: The pub
Member: 236929 Status: Offline Thanks Meter: 12 | u600 camera/restart just powered on when the battery was inserted. Turned out to be a little water ingress around the connectors (keypad and camera flex connectors) Fortunately it wasent to bad and a thorough clean seemed to work. It now switches on and off and the keypad works fine. The problem is(i dont know if it this problem to begin with) The camera although works,is very very slow and once you have taken a picture it resets itselfi know these phones have realy slow cameras anyways but can someone tell me if this is still a hardware fault or wether its a software problem,and what i should do next??? Br DaN |
04-16-2008, 20:23 | #2 (permalink) |
Junior Member Join Date: Apr 2008
Member: 750301 Status: Offline Thanks Meter: 3 | hi there! ive repaire alot of samsung u600"s this camera probblem is a hardware fault. once u hae take a picture, the phone should not reset itself. it is a hardware fault, you can either: replacethe whole camrea moduel,which isa whole unit that consists of camera, powerswitch, ringer,speaker. or it can also be a hardwarefault where youneed to change the camera IC. you can do eiter repair ifyou are a experenced engineer, or you can send the phone to us, we have a retails outlet and do offer a mobile phone reair service. if u need any more info cantact me. many thanks! good luck with your phone! |
04-16-2008, 22:22 | #3 (permalink) |
Member: 236929 Status: Offline Thanks Meter: 12 | hmm thanks. When i say resets i mean just to the u600 screen,not a complete restart. Il try ultrasonic bath and a bit of a reheat on the main board. Prehaps a flash if i get bored,if it dont work after that its going in the spares bin. Im surprised how cheap these are now Dan |
04-20-2008, 18:36 | #4 (permalink) |
Member: 236929 Status: Offline Thanks Meter: 12 | I took the main ribbon(that goes between both boards)out and there was a little more oxadizing on the ribbon,carefully cleaned this off with a pin an some alcohol. Cameras fine now. was hardware then |
U600 Camera Problem "please Wait" | sof940 | Samsung Hardware Repair | 10 | 02-15-2010 08:40 |
u600 get restart or stack if you insert simcard | eljhay | Samsung Hardware Repair | 2 | 06-28-2009 12:19 |
u600 camera connection error... | jazmob | SWIFT Platform | 2 | 06-14-2009 08:58 |
u600 camera strench/freeze | chimeto | Samsung Hardware Repair | 0 | 09-09-2008 08:12 |
U600 camera and memory problem after flashing | pitiless | NSPRO | 1 | 07-07-2007 18:16 |
