04-05-2008, 12:18 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 213733 Status: Offline Thanks Meter: 1 | U600 mic Does anybody have a shematic or any solution??? |
04-08-2008, 20:29 | #2 (permalink) |
Junior Member Join Date: Apr 2007 Location: france
Member: 488275 Status: Offline Sonork: abdell Thanks Meter: 1 | try to get the voice from the headphone place , its not easy but try to mesure that by the machine |
The Following User Says Thank You to saddoukabderrah For This Useful Post: |
04-10-2008, 20:10 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Age: 48
Member: 10580 Status: Offline Thanks Meter: 43 | l have same problem l try all keypad film mic and all mic companents but not workin but l change orginal mic a little voice is gone(work) but voice is very bad not good l try make now not finished if l find a solition to night l ll write here |
05-20-2008, 16:22 | #9 (permalink) |
Freak Poster Join Date: Sep 2003 Location: FRANCE Age: 42
Member: 39679 Status: Offline Thanks Meter: 41 | i tryed all solution , but not working , but the really solution is so easy , just do a custum reset *2767*cust# and all will be ok ! |
The Following User Says Thank You to Gsmtechno For This Useful Post: |
05-26-2008, 15:37 | #10 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: ISRAEL
Member: 215946 Status: Offline Thanks Meter: 120 | Quote:
i have the same problem with u600 mic no work. and till now. i know for sure. that's the problem is hardware problem. i already change the keyped with the mic. and no work. if some one have solution please help us. many thanks. | |
05-29-2008, 11:40 | #11 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | Well... ...I just get one off these phone with mic problem....Shematic's "say's" that prob shoode be in U408 IF You have clean lines from Mic+ and Mic- to U408 ( u can try on C448...one side is Mic+ one is Mic-)...so ...i try to repair these and post result's here...cheers... Manny Shmeatics http://www.shrak-mobile.com/eng/schem_samsung.html |
05-29-2008, 12:19 | #12 (permalink) |
Member: 21365 Status: Offline Thanks Meter: 92 | Like I told before... ..in MY case problem was in U408 BUT......if You dond have practice with glued IC's DON'T LEARN ON THESE ONE!!!!! Cheers. |
09-22-2008, 10:43 | #15 (permalink) |
Junior Member Join Date: Oct 2005
Member: 193310 Status: Offline Thanks Meter: 0 | j'ai un samsung u600 le probleme quand j'ai changé le coq et ba j'ai casé les deux piste de l'antenne qui sont coller dans le cage en bas alors est ce que vous pouver m'aider vous me passer une solution ou le schema de u600 merci |
U600 mic solution 100% tested | adelgsm | Samsung Hardware Repair | 9 | 01-08-2010 14:56 |
u600 mic points r dead | gul-fraz | Samsung Hardware Repair | 1 | 02-06-2009 15:09 |
u600 mic points r dead | gul-fraz | Samsung Hardware Repair | 0 | 01-30-2009 15:19 |
U600 mic & sound problem | Bloodius | Samsung Hardware Repair | 2 | 11-30-2008 19:49 |
U600 mic | kadour83 | Samsung Hardware Repair | 1 | 07-08-2008 17:00 |
