07-05-2009, 23:51 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ENGLAND
Member: 3811 Status: Offline Thanks Meter: 24 | u600 u600b flex any help appriciated ... |
07-06-2009, 00:10 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | No, there is not. But there are 2 PCB rev. and they use same flex foil. http://forum.gsmhosting.com/vbb/show...69&postcount=2 If you are HW unexpirienced, common mistake with that flex is, that you didn't notice that the new foil is longer. (you have to bend it /on a PCB conn side/ to proper placement) Original flex is allready bent (and glued too) precisely - so you probably didn't notice that you can unbend/strech it on a PCB conn side & make it long as your recived one. BR Haltec |
07-06-2009, 16:18 | #3 (permalink) |
Member: 3811 Status: Offline Thanks Meter: 24 | many thanks for your reply new foil is longer but connector looks as though its on the wrong side but i understand that on the lcd side where you solder this can be interted any side up ...... many thanks |
u600 u600b problems | doublex_gsm | Samsung Hardware Repair | 4 | 08-17-2010 01:32 |
U600, U600B, D900i empty boards | Bmt_HR | UST Pro II | 0 | 11-11-2009 15:48 |
Information Show Diffenrent Between U600 -u600b | melgsm | UST Pro II | 4 | 02-26-2009 21:03 |
u600 ? u600b ? flashin problem | Kiano | UST Pro II | 25 | 12-10-2008 10:25 |
