12-08-2008, 06:51 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 919307 Status: Offline Thanks Meter: 1 | u700 touch pad problem |
12-08-2008, 16:42 | #2 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: In a house Age: 46
Member: 249757 Status: Offline Sonork: 100.1601084 Thanks Meter: 117 | Quote:
12-08-2008, 18:52 | #3 (permalink) |
Junior Member Join Date: Jul 2008
Member: 815456 Status: Offline Thanks Meter: 4 | Dear Sarangdotcom Your problem is most definately the flex cable, but if you buy a new flex cable make sure it is good quality because there are alot of sub standard flex cables on the market and it is likely to happen again. Hope it helps. Billycool77 |
The Following User Says Thank You to billycoulson For This Useful Post: |
12-08-2008, 19:08 | #4 (permalink) |
Member: 919307 Status: Offline Thanks Meter: 1 | thank you very much ^^ and i did use the search which is why i suspected the flex cable~ just wasnt sure since the problems were different. especially the screen problem~ it confused me |
12-08-2008, 20:00 | #5 (permalink) |
Member: 919307 Status: Offline Thanks Meter: 1 | man the problem gets worse and worse. now my touch pads dont even work cuz i tried the *#2665# touch key software update code. --; |
The Following User Says Thank You to sarangdotcom For This Useful Post: |
Touch Pad for iPod Touch PDA 2nd - Original (new) | IPMART | ipmart WebShop | 0 | 07-20-2009 12:00 |
Direction Touch Pad for Samsung U700E Phone - Original (new) | IPMART | ipmart WebShop | 0 | 04-14-2009 12:50 |
help needed badly with u700 touch sensitive buttons! | barnesy99 | Samsung Hardware Repair | 1 | 02-24-2009 08:20 |
u700 touch key problem? | X-TRA | UST Pro II | 7 | 12-08-2008 10:23 |
KG800 Touch Pad Problem!!!! | starman_dx | LG | 1 | 08-22-2007 09:11 |
