07-07-2009, 08:41 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1069383 Status: Offline Thanks Meter: 0 | F480 touchscreen doesn't work I dropped my samsung f480 in the toilet, and almost everything still works like it should, but the touchscreen doesn't respond. So when i touch it, nothing happens. I cant repair this with the warranty and i called samsung to ask if they can repair it when i pay for it. But they dont want to do that because the cant ensure it works then. I opened the phone twice now and i saw nothing special, but some things were a bit white. Is that oxidation? What part should i replace? The touchscreen (click) Or the lcd screen? Hope you cant help me. And btw dont mind my english im from Holland. Gerpsp |
07-11-2009, 21:30 | #3 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | You have to disassemble all to get only front panel with small flex tape.(about 10mm long) Yes.White that you have seen that could be oxidation.Try to remove it using Cleanser and tooth-brush.(remove LCD first) There is an element close to connection pads on the flex- as i remember 25 pins.Try to resolder it. This method help me. Last edited by roberts; 07-11-2009 at 21:36. |
The Following User Says Thank You to roberts For This Useful Post: |
07-13-2009, 00:40 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | mate u have to clean ur fone 1st after that change touch pad ....ur poblm will 1000% solve.. |
The Following User Says Thank You to chohansahib For This Useful Post: |
09-21-2009, 17:38 | #5 (permalink) |
Member: 1069383 Status: Offline Thanks Meter: 0 | Thanks for the reactions all and sorry for my late reaction. I tried to change the touchscreen but that didnt work, so im going to try to clean it again. Do you think turpentine will work? I will try cleanser as well. What is the part i have to clean? |
F480 touchscreen doesn't work | samih127 | Samsung Hardware Repair | 6 | 02-27-2010 16:39 |
F480 flashed to F488. touch screen doesn't work properly | Cake | UST Pro II | 0 | 04-13-2009 15:40 |
F480 Touch doesn't work after flash solution | 25011 | QUALCOMM Models (3G) | 0 | 01-30-2009 18:23 |
Ztc f480 touchscreen problem | hans salim | Infinity-Box | 1 | 12-17-2008 23:52 |
UST pro 2 ver 8.30 NEW function doesn't work for me on F480 TOCCO PLZ HELP VAHID | malikzahidawan | UST Pro II | 4 | 10-23-2008 00:47 |
