08-11-2013, 00:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | WCDMA Issues on Galaxy S3 after Water-Damage I have a S3 (I9300) here which had a water damage. I Reballed the PMIC and some other corroded IC's. I had unknown BB after all that, but suddenly, the BB began to work. Now the WCDMA doens't work. I have Signal-bars but i can't see any Data-Communication, also i can't see the H+ or 3G Symbol near the Signal-bars. In normal GSM-Mode works all fine and i can make calls. Any ideas? BR Matthias |
08-15-2013, 15:22 | #2 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Quote:
The Following User Says Thank You to habibboxes For This Useful Post: |
08-19-2013, 06:59 | #3 (permalink) |
Member: 1012778 Status: Offline Thanks Meter: 245 | I have the schematics, but thank you. I reballed now every IC in the RF-Part (except the BB Processor). The Problem is a bit different now, the phone connects to the UMTS Network after 10 mins and sometimes i'm able to call but mostly not. then looses the Network again and reconnect after few minutes again. |
08-19-2013, 12:18 | #5 (permalink) |
Member: 1012778 Status: Offline Thanks Meter: 245 | I have this already reballed and cleaned from the corrosion. the Output-voltages seems to be ok. I have exchanged from another board to test: - U106 - U102 - U103 - U106 - F100 No luck Pls PM me, you seems to be a good guy BR Matthias |
