07-09-2017, 11:16 | #1 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2734818 Status: Offline Thanks Meter: 0 | Why is my battery temperature constantly shown as -20°C? I have a Samsung tablet TAB 4 – SM-T530 which shows problem when charging: charging paused, battery temperature too low. Using an app, I found out the battery temperature is shown constantly as -20°C, even when there is not charger plugged. Do you know where the problem might be? Do you know where the battery temperature sensor is located? Do you know if the battery temperature can be overwritten in order to allow the charging? One blue wire coming from the battery to the motherboard shows 0V constantly, the other blue wire 0.4V Thank you in advance! |
07-12-2017, 14:55 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-T530 charging paused by temperature replace thermistor ntc TH401 | |
