09-04-2016, 14:25 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Below are some of the causes of smartphone battery is explosive and could you jadika the most for your reference. 1. Do not use the official battery There are times when the original battery of your gadgets should be replaced with new batteries. When choosing a new battery, try to buy the battery with the same brand and type of batteries alias ori. Although it is more expensive to 2-3 times more than ordinary batteries, at least ori battery will last longer and can also adjust the default charger. Batteries are not ori are also more prone to damage because it is not designed specifically for a particular gadget. 2. Used when in-charge The next error that is currently in-charge, you do not stop playing favorite gadget. Even just texting, chatting, open the app and play the game, if it is done in a long time, it will make the battery to rapidly overheat and quickly filled. The worst thing is the phone while recharging. Need high battery power when the phone is used, and if the battery is too hot is not possible if the battery is explosive and injure yourself. Sponsored Links Better turn off the gadgets or turn airplane mode to reduce power consumption when searching for a network. 3. Closed objects Charge the battery on the bed or on the pillow should be avoided. Flammable objects into the reason the battery is explosive, especially when the gadget was left with pillows and poorly ventilated. Better charge the battery over a flat surface such as a table or the floor. 4. Using a charger that is not appropriate Make sure only to use the default charger because the charger is already adapted to the battery. Charger that do not comply will take longer to fully charge and potentially destroy the existing system on the battery ori. 5. Charging for too long Reason explosive battery that is next due to the charging process is too long. To charge for too long will damage the battery and does not rule out the possibility to make the battery explode at any time. 6. Avoid heat In addition to the heat from the battery itself, the atmosphere around it can make the battery to rapidly overheat. Laying in the sun exposure gadget will certainly make the gadget along with a hot battery. Especially if you charge the battery near other electronic items such as a refrigerator, microwave and TV. |
