02-20-2008, 20:01 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | in most cases, problem is volume keys ... solution ... just put a very little flux under, and re-heat or .. .change them on many other samsung phones too. p.s. just solved one x210 this way. b.r. ALexandar. |
The Following User Says Thank You to Brka For This Useful Post: |
03-07-2009, 10:41 | #11 (permalink) |
Junior Member Join Date: Apr 2004
Member: 63532 Status: Offline Thanks Meter: 4 | hi all, even before u remove the indicated components remove and clean the volume keys when u check them on board they shows they are good. I get the result when remove the volume keys all other keys were found working. regards |
The Following User Says Thank You to pearlharppy For This Useful Post: |
SGH-X210 Hang Problem Please Help | abdurrahimsagar | Samsung Hardware Repair | 4 | 09-01-2010 11:03 |
x210 hang | m.sapon | Samsung Hardware Repair | 0 | 09-25-2008 15:36 |
Can't repair IMEI on X160 and X210!!! | ionelka | UST Pro II | 9 | 06-18-2007 12:29 |
N70 starts and hangs out | makkan00 | Nokia Base Band 5 ( BB-5 ) | 13 | 05-06-2007 02:40 |
Need X300 and X210 OptiFlasher | invisible990200 | Trident/AGERE Platform | 0 | 09-19-2006 21:08 |
