09-15-2007, 00:18 | #1 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | X200 & X510 always Recharge Battery after water damage anyone have solution for X200 or X510 always say 'recharge battery' after water damage, when battery is full charged (it was ok before clean the board but maybe one component was missed or bad soldered after) witch component will detect mes_batt like other old samsung (330k resistor) thx in advance http:///vbb/showthread.php?t=442010 |
09-15-2007, 08:37 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | The Aftermath Of Water Damage In Mobile Phones Is Usually A Serious One Such That The Mobile May Be Rendered Useless In Many Cases Especially If The User Continues To Use It After Falling Into Water Without Any Thourough Cleaning By Seasoned Repair Engineers. As For Solution To The Fault, I Would Suggest That You First Remove The Power Amplifier Of The Phone And Test It Again With Battery In Good Condition. This However, You Should Do If You Are Sure You Have Cleaned The Unit Well, And The Best Thing To Use Is The Solvent Called Thinner. If The Situation Remains The Same, Then You Probably Have To Suspect The Power Ic. |
09-15-2007, 22:50 | #3 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | thx for ur answer the problem is not on PA, already removed, but phone still can't detect real battery value can anyone post here SM of X510 to see right mainboard layouts with components names thx |
w850 vibrates when putting battery after water damage.??? | blaiseid | Sony Ericsson Hardware Repair | 0 | 08-06-2007 13:42 |
A60 Recharge battery after unlock?? plz help | dave007 | E-Gold Based Phones | 13 | 07-25-2007 22:43 |
V3r after water damage always boot mode | jakrzys | Motorola Hardware Repair | 3 | 06-13-2007 15:11 |
Nokia 3310 Can't On After Water Damage | Williamcwy | Nokia Hardware & Hardware Repair | 3 | 02-04-2002 06:26 |
V.50 not charging after water damage | bluelights | Motorola Old Legacy (EMMI) | 0 | 01-07-2002 18:25 |
