Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-18-2006, 17:52   #1 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
x480 lcd problem... jumper possible?
i got here a x480 lcd problem that after some research on board and after changing lcd fount out that problem comes from ic u203.
Atached i send picture of u203 that i removed but there are some soldering missing. all the red dots are the soldering it have it.
is there any possible wiring solution to replace u203 and to bypass those 2 missing soldering point?
tks in advance
The Following User Says Thank You to sergioems For This Useful Post:
Old 10-24-2006, 20:27   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,340
Hi Friend
only schmm can help you to find out that two missing track
I'll give you schm for x480 hope this will help you
Good Luck
Old 10-26-2006, 15:15   #3 (permalink)
Tilka's Avatar
Member: 172397
Thanks Meter: 10
Ive have x480 ,changet that kontroler and lcd still not work,lcd is fine,flat 2
any other ideas?
china n95 lcd ic jumper needed up the lcd connector shani72 Chinese Models & Cloned Phones 0 02-14-2010 05:23
need lcd filter jumper for nokia 7610 shree59 WD2 & APE (Symbian Phones) 1 08-03-2007 16:35
How to REPAIR 6600 LCD..?? Any Jumper..?? khem Nokia Hardware & Hardware Repair 0 08-24-2006 19:47
any 2600 lcd connector jumper? galo Nokia Hardware & Hardware Repair 2 04-19-2006 19:17
any 2600 lcd connector jumper? galo Nokia Hardware & Hardware Repair 0 04-19-2006 18:47
Page generated in 0.36435 seconds with 9 queries
