10-22-2005, 22:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Novi Sad - Serbia Age: 49
Member: 33912 Status: Offline Thanks Meter: 3 | Z105 charging fault! Please, need help. I have problem with my Z105. Charger is OK. DC out is ~5V-6V. When I put charger connector in, charging indicator is blinking, but it's not charge the battery. Need any solution. HELP! |
12-30-2005, 14:42 | #3 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | try flash first, if charge indicator is blink then charge current has reached processor and software has handled some charge function (charge indicator), just not all... if fails, then you can follow charge voltage around the board: strip phone, connect charger only. take voltage measurements starting at charge block and work round to find where is the problem. |
Z105 charging pins? | et.com | QUALCOMM Models (3G) | 0 | 02-05-2008 12:49 |
z105 charging pins | florinmar | Samsung Hardware Repair | 3 | 11-03-2006 01:16 |
C25 Charging Fault | MrDurst | Siemens Hardware Repair Area | 1 | 02-16-2002 05:08 |
3210 Charging fault | Vicky | Nokia Hardware & Hardware Repair | 7 | 12-10-2001 00:49 |
Siemens S25 charge fault. | Pandemonio100 | Siemens Hardware Repair Area | 2 | 06-11-2001 08:53 |
