Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-14-2004, 14:23   #1 (permalink)
Member: 54462
2x T610 Problems !!!
I have here 2 Faulty Sony Ericsson T610s and have no idea on how to repair these. Any help is deeply appreciated.
1. When I turn on the phone the sounds come on as normal but the screen stays blank. I removed the screen and tryed it on another t610 and it was working fine so the screen is not the fault. I flashed AVR, ARM & GDFS sucessfully but the screen still stays blank.
What should I do?
2. While trying to flash this phone it gets to 2% then I get error 0101. This problem occured after trying to flash this phone a few times. The phone charges fine and turns on but is very slow and often freezes. I need to reflash ARM to fix the freeze problem but the progress bar does not go pass 2%.
I am using a Terminator Dongle + Div 8.4 . I have also tryed DIV USB 2.3 but no sucess.
Any help is deeply appreciated !
Thanks,
t00the
Old 04-24-2004, 01:39   #2 (permalink)
F C
F C's Avatar
Member: 6486
Sonork: 100.79846
Thanks Meter: 350
its hw problem nothing to do with the sw! some thing rong in the flex connection to teh main pcb - may be the flex connector (pcb to the lcd)is damaged or water damaged -- try to resold it !
first always try to use 8.2 --its more stable than 8.4! secondly use se-fighter ur problem wd be solved 100%
best regards
gohar
Sony Ericsson T610 problems, no charge, not a problem with battery or adapter ultrajosh Sony Ericsson Hardware Repair 2 12-10-2008 12:46
Sony Ericsson T610.......Problems yueyo Twisterflasher 16 01-14-2004 19:58
T610 Problems Hami Sony Ericsson 6 01-11-2004 01:24
t610 problem!!!!!!!!!!! sawa Sony Ericsson 19 10-22-2003 14:29
T610 problem after firmware update Yasmin Sony Ericsson 27 08-22-2003 11:38
Page generated in 0.20074 seconds with 9 queries
