Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-18-2007, 22:13   #196 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up T610 speaker
Originally Posted by humtum View Post
t 610 ringer and speaker is one and same, but ringer works and no sound from it while calling,i increase listening volume, and changed the profile h-port to normal ,but nothing happened
can enyone help and post,thanks in advance.
Dear br
check handfree option
and look thses pics
rashid
The Following 4 Users Say Thank You to r a nadeem For This Useful Post:
Old 06-20-2007, 13:53   #197 (permalink)
Member: 392116
Thanks Meter: 18
K310i Mic Problem
hi all member
i find a k310i mic solution but i dont understand this solution. which ic i can jmpering pls indicate me
thanks
Old 06-20-2007, 18:02   #198 (permalink)
Member: 491606
please i need jumper for kypad k800i i have problem with ky 2 - 5 -0 -ok
so i need jumper from kypad to konekter
thnks
Old 06-20-2007, 22:58   #199 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Originally Posted by Deb Chandan View Post
hi all member
thanks
1- change mic
2-clean board
3- check by pic
rashid
The Following 5 Users Say Thank You to r a nadeem For This Useful Post:
Old 06-20-2007, 23:02   #200 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
thnks
dear br
again rehot and check marked parts
rashid
Old 06-21-2007, 00:06   #201 (permalink)
JHON_DREAM's Avatar
Member: 310330
Sonork: 100.1577334
Thanks Meter: 1,449
SIR RASHID,
i need the K750 jonly joy stick ways.i found here your post about keypad & joy stick ways but i can't undersatand from your pic & i need only joy stick ways.my K750 joy stick was brocken & its print was damaged.pls if possibale post here sir only joy stick ways .
BEST OF LUCK.
BR,
JHON.
Old 06-21-2007, 05:51   #202 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
Originally Posted by JHON_DREAM View Post
SIR RASHID,
BEST OF LUCK.
BR,
JHON.
pls search befor ask.
this may help you?
you can make jumper from component saw here to which print is damadge
wbr
The Following 4 Users Say Thank You to baraka42 For This Useful Post:
Old 06-21-2007, 09:15   #203 (permalink)
Member: 491606
[quote=r a nadeem;2526459]dear br
rashid [/qu
im saw the pc but the problem not in crestal bot in flex cable so i need the way bitween kypad to conector
thanks
Old 06-21-2007, 20:46   #204 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
hi brothes i have k750 not work key volume and button music i am chic ic kyebad plesae help me in need photo looking ///
Old 06-22-2007, 01:02   #205 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up K750
Dear check it , try it, reply me ,
Tips and tricks in Sony Eric son!
K750 Tips and Tricks:
Standby Screen:
*#0000# - Reset language back to English
>*<<*<* (>= move joystick right, <=vice versa *=press * key) --> Service Menu
Hold # --> Silent mode
* , right key --> Lock keypad
+ or - while clock is active -->Highlight clock
+ or - in standby --> view phone info
Left joystick --> Write message (default)
Up joystick --> Media player (default)
Down Joystick --> Contacts (default)
Right joystick --> create custom shortcut if not already set
Press any no. then # -->Brings up call from SIM list
Menus:
C --> delete selected item
+ or - --> increase volume if media is playing
Hold back button--> return to stand by
Settings>Calls>Time & cost>Messages counter --> Number of sent messages
Settings>Calls>Time & cost>Data counter --> Sent/Received Data counter
Menu Shortcuts:
1 --> Play now
2 --> Internet services
3 --> Entertainment*
4 --> Camera
5 --> Messaging*
6 --> Media Player
7 --> File Manager*
8 --> Contacts
9 --> Radio
* --> Calls
0 --> Organizer*
# --> Settings*
Camera:
1 ---> picture size
4 --> Macro mode
7 --> night mode
* --> light
up or down --> switch video/stills
+ or - --> adjusts brightness
The Light will flash brighter once the picture is taken.
Taking pictures in full res. or with effects may cause it to lag.
Receiving call:
+ or - or # --> mute ring tone
Hold + or - ---> reject call
Media player:
Silent turned on, media still plays with sound
Full screen video--> More>Full screen
Settings>General>Music Button --> Change Media button function
Radio/Media player
> --> next track
< --> previous track
^ --> pause
+/- --> adjust volume
hold + --> previous track
hold - --> next track
hold > or < --> to scroll back forward media
* and then "lock keys" to lock whilst playing (still able to use +/- to navigate).
Pause video>menu>capture frame -->Capture Video Frame (saved in pic folder must be done in media player).
Press down when u are playing a movie in the media player and it will go in slow motion.
Radio:
# --> Allows you to type in the radio station instead of scrolling through.
Memory:
Be sure to format a blank memory card via the phone before use.
File manger>More>Format
Check overall memory--> File manager>more>memory status
During Call:
Hold C -->mute/unmute
Misc.:
If you run out of SMS memory --> Remove your sent messages, without needing to delete inbox messages.
Hold + Or - in input text screens --> Highlight text
Creating contact pictures --> Zoom in on the face and save as large. Did not try saving as small or other size, so don’t know how it will appear.
Quick Bluetooth --> Assign one of the Navigation key shortcuts to Bluetooth "Turn on". This way, whenever you press up for example, Bluetooth turns on/off.
Quick Add Number --> Type in number then go to "Other" > Save nr. > New contact.
USB Charger takes longer than Wall Charger. The USB charger also doesn't fully charge the phone.
Find out firmware --> Access service menu (see above) then go to service info>software info and it should be on the top line.
Text Files:
Handling .*** files:
* *** files are saved in web pages\save pages folder.
* You can create .*** files with a windows Notepad or any word processing file and then send the file via USB to the folder mentioned above.
* I have noticed that if a Nokia sends me a *** file, when it has opened the first letter of the message appears only. It appears that the text message body is saved in the filename; therefore, a long filename will not appear. Thus to view the message, after it has been save in the saved pages folder, view it's information, and the message will be seen in full. I have experienced this with one user; I am not sure, if the user deliberately types the message in the filename field or if that is how nokia works.
* Another way of creating text files is by using word and saving them as a web page (html). This is useful if you are using foreign characters, as they will sometimes not appear if saved as. ***.
K700 Tips and Tricks:
Standby Screen:
Menu
Hold # or c --> Toggle silent mode
More --> Quick options
+ Or - --> Phone Status
+ Or - when clock is showing --> Turns on backlight
Pressing # and * --> Brings up screen saver
Pressing 7 and 9 -->brings up 9p
*#06# --> Brings up IMEI No.
More>Shortcuts --> to change joystick shortcuts
+ or - Then [Number] --> Quick set volume level e.g. +8 to set at 8.
Menus:
Press letter in address book--> go to name beginning with that letter.
Hold down number --> will take you to the contact with that speed dial in address book.
You can use keypad for fast navigation.
Camera:
1 --> Toggles Picture size
2 --> Toggles Night mode
3 --> Toggles Special Effects
4 --> Toggles Self Timer (not in valid)
5 --> Toggles Flashlight
Joystick Up Or Down --> Toggles Zoom
-video mode: 176 - 2x zoom - 128 - 2x 4x zoom
-pic mode: 320 - 2x zoom - 160 - 2x 4x zoom
Put phone in silent --> Mutes camera noise (only on some phones)
Hold * and move joystick down --> Lowers brightness
Hold 0 and move joystick up-->Increases brightness
Use binoculars> Get more than 4x Zoom
Press C after photo taken --> Delete w/o the need to browse through the folders.
Media player:
+ or - during radio and locked --> Changes radio station when phone is locked.
1 --> Shows estimated time left (seconds)
2 --> Turns it back to normal time view (seconds already past).
Hold + or - --> Next Track
Use folders --> Organize music e.g. rock and/or get rid of ringbones (create music folder).
*>More -->can lock keys w/o minimizing.
Misc.:
Supports Animated wallpapers
Joystick can be customized, ALL four directions.
Settings> display> light> automatic --> Turn the screensaver clock on.
Left soft key when playing slide show -->Pauses slide show.
Create New Bookmark >Name: Sms >URL: sms: >Save >Set Bookmark as Homepage --> Set online Key for SMS.
Name: Email >URL: mailto: --> same as above but for email.
Hold * >get p- used for skipping voice automated phones e.g. instead of phoning 603123456 then pressing 32 to go to those options dial 603123456p3p2.
Send *** file to others folder>send via mms -->Can read *** files.
More when viewing picture --> photo editor (only available on 160*120 sized pics).
Photo editor> + or - --> Effects (ripple, emboss etc).
When replying to ***>More > Add Item > Original Message --> Include original message.
When receiving a call> - Or + --> Will stop both the vibrate and the ring tone but it will not reject the call.
During call press + then - --> Increases volume to max.
Hidden smiles (in sms):
:-x --> Hidden Kiss Smiley.
:-] --> wide smile
:-[ --> wide frown
[:] --> Robot
T And Z Series Tips and Tricks:
Standby Screen:
< --> leads to the first item on shortcut list
Holding down corresponding number on the keypad --> Will lead you to the corresponding name in your address book. i.e.: holding down #5 will lead to letter "j" on your book.
# --> brings up screen saver.
More>Post --> Can post notes.
Press # then no. --> Goes to no.'s contact on sim.
Hold < --> SMS Popup.
Hold C --> Silent mode
Menus:
Hold back --> Returns to standby screen
Contact edit:
*1 -> cut
*2 -> copy
*3 -> paste
Camera:
1 --> Toggles Picture Size
4 --> Self Timer
Up Or Down --> Adjusts Brightness
Misc.:
On the calendar, you can set your phone to switch profiles at a given date and time using the auto switch option.
Put frequent text recipients as an individual group. i.e. group” john" members: john -->Quick SMS Recipients.
P Series Tips and Tricks:
Flip Closed then Jog-Up * Jog-Down Jog-Down * Jog-Down * --> Service menu.
Go to the Control Panel > Connections > Internet Accounts > other tab >Preferred mode to GSM only --> Increase Battery Life.
File manager> open image> choose the folder that the pics are in> check the pictures you want to hide> click on file> properties> check the hidden box --> Hide Pictures.
If you ever find your icons (apps residing in memory stick) missing out all a sudden, do not reset you phone but simply reload your memory stick.
*#06# --> Shows IMEI No.
Flip Closed then jog dial down * * jog dial down --> Network Lock Menu. Be carfull o not mess around in this setting as you could end up permanently locking your phone!
You can have animated gifs for flipped closed wallpaper.
Hold C --> Silent Mode
**61*Voicemail Number*11*delay#[SEND] --> Diverts unanswered calls to voicemail after a set delay The delay can be anything from 5-30 seconds. Your Voicemail Number must be your actual voicemail box. Not the short code i.e. 121 for example **61*+44123456*11*30# will divert to +44123456 after 30 seconds.
Battery Tap the battery icon in the bottom right and click Settings. Click on the Screen tab and set the Screen saver to none. Click on the Power tab. set the Light to Auto, Light (car) to off. Set Power saves to either Clock or Blank and Activate after 2-3 minutes. --> Increase Battery
Life
View SMS> edit> Show subject --> See more sms in one page.
Flip Closed> Hold Options key --> Go straight to applications menu.
If you open the flip during a call, the speakerphone function is activated. This lets you continue the conversation while using other functions of the phone.
__________________________________________________ ________________
k750i: Press down when u are playing a movie in the media player and it will go in slow motion.
rashid
The Following 13 Users Say Thank You to r a nadeem For This Useful Post:
Old 06-22-2007, 02:41   #206 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
thanks[/quote]
Dear Br
its schematic of K800, check it may this help ful for you
rashid
The Following 10 Users Say Thank You to r a nadeem For This Useful Post:
Old 06-22-2007, 12:28   #207 (permalink)
JHON_DREAM's Avatar
Member: 310330
Sonork: 100.1577334
Thanks Meter: 1,449
this may help you?
wbr
SIR BARAKA, THANKS for replay.
sir i siad there i use serch here & i find this pic.but its not enough clear.
for that i want here a more clear pic if any body have.
if i wrong any thing,sorry for that sir.
BEST OF LUCK.
BR,
JHON.
The Following 2 Users Say Thank You to JHON_DREAM For This Useful Post:
Old 06-22-2007, 14:33   #208 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
k608i crystal ic power key jumpers
the phone have crystal ic up (under the spk connector ) broken and phone no switch on but is all ok,it go in work only whit charger connected.
i need jumper scheme for solve.
big tnks.
sorry for duplicate but i need fast.
The Following 2 Users Say Thank You to nykocam For This Useful Post:
Old 06-22-2007, 23:29   #209 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up Dear
BEST OF LUCK.
BR,
JHON.
Dear jhon
see one more pic may this helpful to you
rashid
Old 06-23-2007, 00:44   #210 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
big tnks.
Dear Br
check marked parts and check also power switch to D452 + C465 + CN453 pin no, 8 + CL026 to link , one side of power switch power switch is GND
rashid
File Type: jpg K750%20on%20off%20and%20iluminations.JPG (106.6 KB, 952 views)
The Following 6 Users Say Thank You to r a nadeem For This Useful Post:
SonyEricsson schematics hs.com Sony Ericsson Hardware Repair 18 07-24-2012 15:45
Schematic and manual all sonyEricsson xagoluyxa Sony Ericsson Hardware Repair 3 10-13-2010 10:19
sonyericsson schematic need alex yong Sony Ericsson Hardware Repair 5 04-22-2010 17:29
i need more sonyericsson schematics uniquephone Sony Ericsson Hardware Repair 0 03-02-2008 06:34
NEED ALL SONYERICSSON Schematics,THANKS! mikejackson Sony Ericsson Hardware Repair 4 05-02-2006 08:48
Page generated in 0.34375 seconds with 10 queries
