Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-17-2009, 11:42 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | brother after flash it the prob is same v0.915038/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors CFG:000000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302313651 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):W580i MAPP CXC article: R8BA024 prgCXC1123476_CHINA_LA MAPP CXC version: R8BA024 Language Package: APAC CDA article: CDA102774/14 CDA version: R2A Default article: cxc1123364 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BA024_CXC1123476_CHINA_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 56 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302313651 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "E:\d\s e tool\flash files\Sonyericsson\w580\cid52\R6BC002_1123362_GENE RIC_LA.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "E:\d\s e tool\flash files\Sonyericsson\w580\cid52\R6BC002_FS_S_ASIA_LE VAN_LA_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4500 Will flash 225 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 427 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302313651 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER setGDFS_params failed failed to setup GDFS Elapsed: 55 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302313651 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER setGDFS_params failed failed to setup GDFS Elapsed: 17 secs. |
08-18-2009, 19:11 | #9 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Kuala Lumpur Age: 43
Member: 287805 Status: Offline Thanks Meter: 132 | change the upper flex... make sure its compatible with it coz there have 2 size of connector (big/small)... allready done it in 7 unit of w580 and s500 |
08-29-2009, 16:40 | #10 (permalink) | |
Temporary banned !! Join Date: Oct 2006
Member: 374340 Status: Offline Sonork: 1604089 Thanks Meter: 26 | w580i Quote:
(Change red marked one) Last edited by annublr; 08-29-2009 at 16:46. | |
The Following 3 Users Say Thank You to annublr For This Useful Post: |
550i "Another application is running close it and then start the camera" | pakmobiles | SETool2 | 3 | 05-21-2011 08:27 |
plz help k770 another application is running close it then start the camera | AKKELECEN | Sony Ericsson Hardware Repair | 7 | 12-27-2010 17:49 |
k530i Another application is runnin. Close it | rajni | Sony Ericsson Hardware Repair | 0 | 10-09-2009 12:53 |
w850i another application is running close it.and then start the camera help | pakmobiles | Sony Ericsson | 1 | 09-13-2009 20:26 |
k800i when camara take.....another application is running.close i | CHAPRAN | Sony Ericsson | 3 | 01-27-2007 14:55 |
