Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-17-2003, 10:13 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | Bad noise on t20 Speaker When i remove the mic,it cuts, I changed the mic and mic cable,but not solved. plkease help |
01-17-2003, 22:14 | #3 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Try to clean very well the contact betwean mic and cable ?maybe dirt .(worked for me)..If not the path to the bga chips is simple chack it could be bad filters...if this doesn't work try what jero says but is judt one responsable for audio (see schematics) |
01-19-2003, 21:11 | #5 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi, here there's many things to test: - May be you have bad mic quality. - Audio filtring is bad. * passive filter such as some RLC bridge * Active filter such as the audio IC and the proscessor. So make a good flux and rehot all Audio circuit( be carefull to not heat the CPU very well elese your phone will go forever). use service manual to test RLC filtring. good luck |
1600 while callling bad noise in speaker.. | broken_rules | Nokia Hardware & Hardware Repair | 21 | 10-30-2008 10:52 |
Motorola T192 noise on speaker | Porter | Motorola Hardware Repair | 5 | 10-20-2005 23:54 |
Sagem 922 no sound but noise on speaker | florinmar | Sagem Hardware Repair Area | 5 | 08-11-2003 17:55 |
Bad noise on N100 speaker and Mic | .::AkhavanGSM::. | VLSI, Conexant, Skyworks and Old Models | 0 | 11-30-2002 18:03 |
Bad noise on N100 speaker | .::AkhavanGSM::. | Hardware Repair by brands | 0 | 11-30-2002 18:02 |
